I agree that you should check the tread width.; 7.3" on a tire that is 7.67" section width seems a bit much but it can be that wide. Even so, I am reasonably sure you can install without rubbing thanks to the short tire if it is really 22.67" diameter. I haven't been to Bridge's site but check that the diameter is not 23.5" or so because you may then get rubbibg.
