Quote:
I know im gonna get flamed for this, but the PRSB also doesnt have any function.
A rear swaybar only functions if the center portion is mounted on the frame of the car to reduce the roll. If it is simply bolted to the cups for the springs it will do nothing but add weight. A rear sway bar installed properly will cause too much oversteer on the Fit. This is why Ben only made a front sway bar. Why? Cause the rear isnt needed.
LOL you don't know how the Progress sway works and you are talking bad about it...
just because it isn't mounted like traditional swaybars doesn't mean that it doesn't work. it functions exactly the same way but it's just mounted differently.
*i don't know how the progress swaybar works therefore it doesn't work*
