View Single Post
  #1 (permalink)
Old 05-21-2008, 10:17 PM
Sugarphreak's Avatar
Sugarphreak Sugarphreak is offline
Master FitFreaker
Sugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond reputeSugarphreak has a reputation beyond repute
The Lethbridge AutoX!
Ok, for those of you who don't want to wait until September to test out all the new parts and put your sharp Fit driving skills to the test.... let's get a date setup for a roadtrip down to Lethbridge for some serious fun!
Available Dates:
July 6 - Event 4 (Exhibition Park, Lethbridge)
July 20 - Event 5 (Exhibition Park, Lethbridge)
August 4 - Event 6 (Exhibition Park, Lethbridge)
August 10 - Event 7 (Exhibition Park, Lethbridge)
Stuff you NEED to know:
1) You need a SNELL 2000 or greater helmet, DOT is not acceptable
2) Pre-Registering will save you 10$ and guarantees you a spot (not open for sign up yet)
https://www.karelo.com/enter_res.php?&BID=334#Ev6095
2b) Bring proof that your pre-registered!
3) Read the supplementary rules
http://sascsolo.ca/forum/download/fi...322771821a 84
4) Leaving early (without consulting early with organizers early on) or not doing the required volunteer Marshalling work will give you a big fat DNF for your times.
Stuff you probably should know:
1) Run about an extra 10psi in the tires
2) Bring painters tape or white shoe polish... or both
3) Bring Suntan lotion, Wear appropriate clothing, umbrellas are your friend!
If you want to go; post up all of the dates that work for you below! Put them in order starting from the most preferred to least preferred.
(Also List your engine, wheels & suspension modifications below so we can establish your vehicle class for the pre-registration.)
__________________
100% Naturally Aspirated,Pure Performance
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Sponsored Links
