View Single Post
  #175 (permalink)
Old 05-23-2008, 03:50 PM
pcs0snq's Avatar
pcs0snq pcs0snq is offline
pcs0snq has a spectacular aura aboutpcs0snq has a spectacular aura about
Quote:
Originally Posted by Fray Adjacent View Post
That seems odd, man. I know in my Fit, when the gas light comes on, I can put about 8.7 gallons in before the pump stops.
If your E light came on at 402, then you put 10.3 gallons in just 31 miles later, you burned about 1.4 gallons over that 31 miles, which is 22mpg.
Unless your Fit's gas light doesn't come on until the tank is like 9.5 gallons down, something is off. Have you ever immediately put gas in when the light come on? How much?
Something is wrong with your math for sure or you forgot about the reserve????
The reserve is the gas in the tank AFTER the E light comes on.
10.8 is the tank total all fuel less filler neck including the reserve.
I do not have my owner manual here, but 10.8 is including the 1.7 reserve??
That is, expect the E light to be on at 10.8 - 1.7 or 9.1 gal US.
Also if you pump at HIGH speed flow, it will shut off before being full.
Look at my last fill that was just after the E might came on. looks at the gals used to reach the E might. That's correct and repeatable
See it???
I've looked at that and talked about it a number of time in the MT MPG thread.
__________________
Paul
2008 VBP Fit Sport Man 5 spd trans
208US Gal saved in the last 20,000miles
