Optimum Ambient temp for Eco
Old Jun 3, 2008 | 09:04 PM
pcs0snq's Avatar
As it gets hot a humid here, I'm very sure I'm seeing worse mpg when the temp is 95F PM ride from when it's 80F AM SG data
Anyone else see that?
Do we know what the best ambient temp is for Eco?
Old Jun 3, 2008 | 09:50 PM
i would say 25F-32F and dry using non-winterized gas.
Old Jun 3, 2008 | 11:11 PM
pb and h's Avatar
I am with you Paul, it was 92 here in the dirty south. A/C is a must unless you want to ride in the fat farm death trap. Hell, I might be able to loose weight and save on gas at the same time if I don't use the A/C!
Old Jun 4, 2008 | 02:08 AM
MINI-Fit's Avatar
My guesses
Not good for mpg:
Hot weather
High Altitude
High Humidity
Since running the AC might be harder on fuel use- testing with lower temperature like 40 degrees means no AC- this is good.
Note that low temps are not good for battery driven hybrids since power is lower with low temps.
see
The Center for Auto Safety
Old Jun 4, 2008 | 09:03 AM
RichXKU's Avatar
Intake air temps of 75-90 with low humidity seem to give good results. Cold air (<50°F) is no good because it requires more fuel to be dumped to keep the correct air/fuel mix, and the engine takes longer to heat up.
Some hypermilers build hot-air intakes which pull hot air off of the catalytic converter to maintain warmer intake air temps, as well as engine grille blocks so less fuel is burned to keep the engine at operating temp.
Old Jun 4, 2008 | 05:58 PM
pcs0snq's Avatar
My SG intake temp in the afternoon is 100 to 110F
cralford
Dec 8, 2014 06:05 PM
Chairman Kaga
Sep 4, 2012 12:13 PM
warner
Sep 13, 2009 10:54 AM
ChefMark
Jul 10, 2008 04:43 PM
Firebat666
Jun 11, 2008 11:55 PM
