View Single Post
  #8 (permalink)
Old 06-05-2008, 12:35 PM
FitPilot FitPilot is offline
FitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to liveFitPilot relies on Rep Points to live
Quote:
Originally Posted by pcs0snq View Post
I will add if you run side wall pressure (like I do), make sure you check the tire pressure hot, as they will increase in pressure.
I'll guess the bashers of this item on here will find some other reason to not, but heck who cares if the keep it to thereself and not spread bogus information.
I read an article somewhere on tirerack's website that stated that the max pressure on the sidewall was a cold pressure (in other words fill it to that when its cold, there is allowances for the expanding air as it heats up).
