View Single Post
  #15 (permalink)
Old 06-05-2008, 09:09 PM
pcs0snq's Avatar
pcs0snq pcs0snq is offline
pcs0snq has a spectacular aura aboutpcs0snq has a spectacular aura about
Not buying it, sir
Do your tires say anything about HOT or COLD on the listed "MAX Press" side wall?
Never seen that and that's why it's not at some specific temperature.
Pressure is a function of temperature and the idea is do not exceed the side wall pressure listed at any temp. Most users do not inflate to max they use the door jam figures. As we are talking about using Max for Eco reasons and being an engineer, I just figured I'd suggest to measure them hot, to make sure they do not exceed tire spec's. It's what I did and was not a big deal.
BTW The Dunlap Sport OEM tires at rated at 1102lb's at 51psig.
That's 4408lb max to tire rating
My M5 Sport weight (according to Honda) is 2471lb
11 gal of gas is 70lb
1867 payload.... for tires
Page 147 of my 2008 owner manual says 850lb max hmmmm seem to of last 1000lbs
__________________
Paul
2008 VBP Fit Sport Man 5 spd trans
208US Gal saved in the last 20,000miles
