Quote:
Originally Posted by pcs0snq
Not buying it, sir
[snip]
BTW The Dunlap Sport OEM tires at rated at 1102lb's at 51psig.
That's 4408lb max to tire rating
My M5 Sport weight (according to Honda) is 2471lb
11 gal of gas is 70lb
1867 payload.... for tires
Page 147 of my 2008 owner manual says 850lb max hmmmm seem to of last 1000lbs
No problem.
Not sure what the numbers were intended to say but the load limitation is the suspension, not the tires. You'll bust the springs before you bust the tires.
