Eco FIT wishlist
Old Jun 11, 2008 | 01:16 AM
Arizona Notch's Avatar
Eco FIT wishlist
So, of course I have had nothing but praise for my Fit since purchasing it nearly three months ago, but I got to thinking of things that would really bring the car to the next level economy wise. Below is my wish list of items that could be added to the Fit to increase economy in order of ease of implementation.
1. Load-based, or TPS-based cruise. This is almost a freebie cost-wise for Honda since all it would take would be some R&D work to get the programming into the ECU to make it work. The computer already computes load based on a number of sensors, one of which is the throttle position sensor (TPS). A load-based, or TPS-based, cruise would help immensely with fuel economy of any vehicle, but especially those with smaller engines as it would keep the engine from working harder on uphill sections of roads, thus improving fuel efficiency. Overall, shouldn’t raise the price of the vehicle much, if any, to add this feature.
2. Taller gears in the transmission. Again, pretty much a freebie with regards to cost to Honda since they already cut gears to go into the transmission. All that would be needed would be some more R&D work to determine if taller gears would help the fuel efficiency of the Fit and implementation if they do. Again, shouldn’t raise the price at all to implement.
3. Better aerodynamics. The Fit is basically a shoebox. OK, so it’s a rounded shoebox with some good styling, but it’s still no Corvette. That’s great and one of the reasons why I love it. The Fit has great utility and cabin space for its small size. Still, I can’t help to think that the a little more aero work, particularly over the top of the car with a slightly reduce overall height above the beltline with a more raked windshield and some undercarriage work to smooth the under side of the car would go along way to helping the fuel economy of the car, especially on the highway. Maybe the next generation Fit coming in 2009 addresses some of this. This shouldn’t add too much to the overall cost of the vehicle. Again, some R&D work by Honda in the wind tunnel and maybe a few under carriage panels to smooth air flow. Figure about a $200 increase in overall price of the car.
4. Addition of variable valve lift (i-VTEC). Honda already has this on many of its cars, so why not the Fit? One reason I can think of is that is would add more cost and more complexity to what is currently a pretty basic car and drivetrain package. The addition of variable lift on the Fit (which I think some euro-spec versions of the Fit already have) would again help significantly with the fuel economy aspects of the car. This one would add a lot, relatively speaking, to the final price of the car. I’m guessing around $500. Although, it may not be that much since I think they already have it on some other versions of the Fit around the world.
5. Addition of a six gear to the transmission. By helping to bring the RPMs down during highway speed cruising, fuel efficiency is sure to go up. I almost couldn’t believe the amount of RPMs the engine was turning at only 65mph the first time I drove my Fit. I kept thinking I was in fourth gear and not fifth. I have since gotten use to it, but feel strongly that a six gear would help tremendously with highway mileage. So, figure about another $500 increase in the price of the car to get this much needed option.
6. Direct injection. Many new engines are turning to gasoline direct injection to help with not only fuel efficiency, but also emissions. Why not the Fit? Again, I have to think this has more to do with where the Fit is positioned in the market with its reputation as an “economy” car more than anything else, but I could be wrong. I don’t believe Honda has any US-spec vehicles right now with DI, but they have to be working on it. So, it would only seem logical that it could be adapted to the Fit. I’ve seen fuel consumption reductions ranging from 10 to 35% depending on engine size with DI, so figure 10% for the Fit. That’s an increase of at least 3mpg with this option alone, so I think it makes sense to do it. I’d say it would add about $700 to the price of the vehicle.
7. Turbocharged, “high feature” engine. Now this is, of course, my ultimate dream for the Fit, but one that doesn’t seem to far fetch when you read much of the literature about where gasoline, and diesel, technology is going. This engine would be a four-cam, 16 or 20 valve, i-VTEC, direct-injected, turbocharged wonder sporting only 1300cc, 1250cc, or even 1200cc worth of displacement. A small multi-vane turbocharger would easily fit in the area currently occupied by the exhaust manifold right now and with some extra tubing and a small, front-mount intercooler your only looking at about a 100 pounds of extra weight, at the most, that would be added to the vehicle. That includes the i-VTEC system because some of the added weight would be offset by a smaller block as a result of downsizing the engine. The turbo motor would make only about 15 more horsepower than the current engine (so 125hp), but make much more torque (around 160). Thus, providing improved acceleration with and less fuel consumption at cruising speed due to the decreased displacement of the engine versus the current 1.5L. This option I figure would add about $2,000, maybe less, to the price of a Fit. Maybe not the most economical idea, but I think well worth the try. It could be a new, top-of-the-line version of the Fit that not only has better performance, but also has better fuel efficiency as well. It could be called “Type S” or something.
So, with those seven ideas out there, what do you think would make a good option to add to the Fit to make it more fuel-efficient?
Old Jun 11, 2008 | 01:17 AM
solbrothers's Avatar
1. scangauge
Old Jun 11, 2008 | 01:43 AM
Sugarphreak's Avatar
Push My Button
Hey nice writeup. I agree with most of your points. Enjoy your new green rep dot
1) Great idea, I think cruise should be a standard feature on all cars
2) & 5) A 6th gear would give you the taller gears you are looking for
3) Rear diffuser would do wonders IMO
4) The current layout is pretty slick 12/16v configuration, I wouldn't change
6) Totally agree with high pressure direct injection, much higher efficiency
7) Also agree, however I would build on it a bit. VW has been working with a Turbo & Supercharger philosophy which is yielding very promising efficiency. With focus on efficiency rather than power I think the Fit could benefit from a higher compression setup. Although then it would not be able to take regular fuel. I cherish my regular gasoline
I think the Fit was built as a reliable economy car, no hybrid technology or complicated parts, just a simple gas engine. I think they have hit the mark. I don't really believe in hybrid cars as battery technology isn't where I think it should be yet.
Old Jun 11, 2008 | 11:59 AM
kamakurakid's Avatar
Like all the engineers at Honda have not put these ideas forth already? I spent nearly a decade with automotive engineers in Japan, they are car nuts and would do all this in a heartbeat. There are limits imposed by the marketplace, the vast majority are thrilled with the car as sales figures and reviews would show. Most of what you are seeking is available aftermarket anyway. Frankly, I would like to see what Acura would produce given a Fit like car to work with.
Fire the ideas off to Honda and see if it makes a difference.
Old Jun 11, 2008 | 12:26 PM
danjor's Avatar
love your post and way of thinking. has anyone tried using taller tires like 175 70 14 or 175 75 14 these can lower gear ratio 4 to 6 percent. or is there another honda transmission or gears that can be swaped in? I dont mind having to downshift to fourth for steep hills for better mpg highway? also isthere a way to turn off the vtec i dont need it cruising on the highway .
Old Jun 11, 2008 | 02:22 PM
dank24's Avatar
i-vtec would suck. That is what the ep3 has and it horrible gas mileage. vtec kicked in at 2,200 rpm on one cam. I got around 22-25mpg. freaking sucked ass.
Old Jun 11, 2008 | 10:17 PM
I'm sure the model you are reffering to has cam profiles designed more for performance than economy, at least on the "small" lobe. What I'm thinking of would be a lobe profile that would be smaller (less duration and lift) for the regular/economy profile than the lobes in the SOHC Fit motor now. The "bigger" lobe would have slightly more duration and lift than the current Fit lobe and be tuned to come on at 3,700rpm or so. So, you would get slightly better fuel efficiency at lower rpm/load and more power at upper rpm/load. It seems like a win-win situation to me. Maybe I'm wrong.
By the way, the Yaris has variable lift (VVT-i) and still gets great gas mileage and achieves a ULEV-II rating.
Old Jun 11, 2008 | 11:41 PM
dank24's Avatar
Yea, my wife just bought a yaris. Our 06 TL was kicking our ass driving 240miles round trips 4x/week.
Old Jun 11, 2008 | 11:53 PM
FIT4LIFE's Avatar
I believe the all new, redesigned 2009 Honda Fit addresses some of your concerns. The all new 1.5 liter engine that will come in the all new '09 Fit has i-VTEC. Also the new Fit is definitely more aerodynamic as compared to the current Fit. Hopefully fuel economy will improve on the '09 Fit as well. With gas prices going up, up, up I wonder if Honda will reconsider and give us the new 1.3 liter i-VTEC engine for the base Fit.
Old Jun 15, 2008 | 07:56 PM
Gordio's Avatar
Aerodynamcis is the big one for me. Many larger cars than the fit sometimes gets better mileage.
Old Jun 15, 2008 | 10:41 PM
Any examples beyond the obvious Prius? Just wondering, sometimes I need to break out a fact or two in a bet type conversation.
Old Jun 15, 2008 | 10:44 PM
1. scangauge
Ought to be standard in all vehicles, might be if the government gets going in a proper govt.
Old Jun 16, 2008 | 12:26 AM
wdb's Avatar
wdb
These are all ideas to improve the current (USDM) car.
I'd like to find some underbody panels in the aftermarket that fit my Fit and not just the JDM models. Specifically a rear diffuser, maybe a larger front undertray. Smoothing out the airflow under the car will help the shoebox I own to be more aerodynamic.
I'm also thinking about lowering springs for the same reason, but I don't want anything too radical. Just a wee drop to improve the aero.
A taller final drive would be nice too. 1st gear is over in a microsecond and 5th is too short; a taller final drive would move them all up.
Old Jun 16, 2008 | 12:49 AM
Fire up that VISA card. All answers come with cash.
Old Jun 16, 2008 | 03:17 AM
wdb's Avatar
wdb
Does that mean you know where I can get the stuff I'm looking for? Or does it mean you're just shooting off an answer without really adding anything to the thread.
Old Jun 16, 2008 | 07:24 PM
undertrays: DIY dude. or have someone make them for you for $$$$.
lowering springs: buy some. progress has a subtle drop.
taller final drive: it'd have to be custom and most likely be $1k+. think how long you'd have to drive and save gas to re-coop the cost.
Old Jun 16, 2008 | 07:41 PM
BlackCobra's Avatar
But if all of this were options in the FIT when we bought it then we wouldnt have these concerns...i know that if they were an option then i would have gotten them as well as most FIT owners.
Old Jun 16, 2008 | 07:46 PM
i think an undertray would be cool, but idk about a taller final drive. i'd kill for a 6 speed manual though
Old Jun 16, 2008 | 10:35 PM
wdb's Avatar
wdb
Or use the search function:
https://www.fitfreak.net/forums/fit-...nderpanel.html
One down, one to go.
Still using the search function on this. I don't want to sacrifice very much at all in terms of ride, and I want handling to be at least as good as stock. For example, I run Prodrive springs on my STi; least drop of any of the aftermarket springs, improved ride quality, improved handling. I want to find the equivalent spring for the Fit.
True, but the benefits would not only be fuel economy; I expect it might add some longevity too. Eh, it's a pipe dream in any case. I'll keep working on the others.
Old Jun 16, 2008 | 10:39 PM
i don't believe the beatrush piece fits the USDM. that's why i didn't mention it. i was interested in it until i heard it doesn't work for our cars.
