The back tires are hardly worn after 26K miles so I coulnd't justify replacing them yet. The back tires barely got hot at last month's event so I'm hoping that the large difference in front to rear grip will result in oversteer to get throught the corners quickly. If not then maybe you will be right and it will turn out to be stupid. I'm looking for a set of Saturn wheels and will get them setup for track use only with proper tires on all four corners.
