Quote:
Originally Posted by JDMGD3
I have a Odyssey battery which is identical to the Buddy Club and others of the same size. It works fine for daily use as long as you drive your car on a pretty regular basis. It doesnt have alot of reserve amps like its bigger normal sized counterparts also the colder the climate you live in the quicker it will lose charge. I have a small charger that I use on it if I know im not gonna be driving for a few days or your actually better off disconnecting the battery. The battery itself is only 14lbs so its a good way to reduce some weight also.
That's too bad about the reserve issue. I want an Odyssey for the weight savings, but I'm not sure I'd be using the car daily.
Do you know how much the stock battery weighs?
