Quote:
Originally Posted by atlas
does anybody know if any Braile batteries fit?
Fitment as far as batteries go arent an issue as long as there equal to or smaller then stock which the Braile is. The Fit's stock battery is substantially smaller then your typical stock battery due to the the motor being so small. I highly doubt it weighs anymore then 25lbs and the Odyssey I have which is the same identical to the Buddy Club also the IDI Racing Battery and all those weigh around 15 to 16lbs. At the most you will be saving about 10lbs in weight if you do the upgrade.
