View Single Post
  #107 (permalink)
Old 06-17-2008, 12:09 AM
wdb's Avatar
wdb wdb is offline
wdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to livewdb relies on Rep Points to live
I sure would like to see some updates to this post. Having all of the information in one place would be a great way to welcome Fit n00bs like me to the forums!
Quote:
Originally Posted by scsi View Post
If you are able to provide or correct any information on springs, please do so in this thread and I'll try to keep this updated. Also, if you feel other information should be added, please suggest.
If you have side-view photos of your car, preferrably on stock wheels and tires, please post them here and I will add them as well. If you have aftermarket wheel or tire sizes, please post those as well. Again, stock wheels and tires are preferred for comparison.
__________________________________________________
Key Information
Advertised Drop: Front/Rear in. (Front/Rear mm)
Advertised Spring Rate: Front/Rear lbs./in. (Front/Rear kgmm)
Linear or Progressive
OEM
Spring Rates?
Eibach Pro-Kit
Advertised Drop: 1.6/1.3 (40.6/33.0)
Eibach Sportline
Advertised Drop: 2.0/1.8 (50.8/45.7)
H&R Sport
Advertised Drop: 1.6/1.4 (40.6/35.6)
Progress
Advertised Drop: 1.5/1.3 (38.1/33.0)
(CarDemon)
Skunk2
Advertised Drop: 1.5/1.0 (38.1/25.4)
Advertised Spring Rates: 175/350
Spoon
Advertised Drop: 1.5/1.0 (25.4/25.4)
Advertised Spring Rates: 195/291
(macks75)
Sprint
Swift
(Jimmy101)
T1R S-Coil V2
Advertised Spring Rates: 179/342
(aj-racing.com)
Tanabe DF210
Advertised Drop: 1.8/1.3 (45.7/33.0)
Advertised Spring Rates: 174/274 (3.1/4.9)
(jits14)
Tanabe GF210
Advertised Drop: 1.5/0.9 (38.1/22.9)
Advertised Spring Rates: 190/279 (3.4/5.0)
(bulletproofautomotive.com)
(4dr4life!)
Tein H.Tech
Tein S.Tech
Advertised Drop: 1.8/1.2 (46/31)
Advertised Spring Rates: 163/336 (2.9/6.0)
Vogtland
Advertised Drop: 1.6/1.0 (40.6/25.4)
(RacerDre)
Zeal X-Coil
Advertised Drop: 1.0/1.2 (25/30)
