DIY: T1R Crankshaft Pulley
Old Jun 18, 2008 | 12:54 AM
Fit of RAGE's Avatar
Here's my new toy:
DIY TIME
1: Note and draw out a diagram of how the drive belt is routed. Here's what my routing looked like.
2: Take off the 3 tabs to take the cover off. (it's not 100% off, it's just out of the way)
3: Loosen off the alternator hold-down bolt. The bottom one is REALLY difficult to get to so i left it tight. Now loosen the adjuster bolt. DO NOT REMOVE THE BOLT!! Make sure there's still some threads left.
4: Remove the drive belt from the car.
5: Spray some "Penetrating fluid" onto the crank bolt to help it off. I HIGHLY recommend using an air tool. It's REALLY tight!! It's a 19mm bolt
6: Note the location of the alignment key. DO NOT REMOVE or LOSE IT!!!
7: Remove the pulley. Here are some pics of the new VS the old. It's also got timing marks!!!
8: Install the new purple pulley
Now reverse the order in which you've done everything.
***BEFORE STARTING VEHICLE, MAKE SURE YOUR BELT IS ALIGNED PROPERLY. RUN CAR FOR A FEW SECONDS TO MAKE SURE EVERYTHING IS OK***
FINISHED!!
Now, it's time for the (test drive)
Honestly, i didn't notice much. It seems to pick up quicker, but it could just be psychological. Either way, I'm happy with it. Theoretically, it works so good enough for me. (for now since it's only a daily driver)
Old Jun 18, 2008 | 01:13 AM
runnin9z's Avatar
O man you are going to be in for some fun, that stock pully is on there at close to 200 ft lbs, at least thats what it was on my Rsx, make sure you get the honda crank pully tool by powerbuilt, or you will be in a world of hell.
Old Jun 18, 2008 | 08:52 AM
I'll be doing it at the shop that i work at. AIR TOOLS BABY!!
Old Jun 18, 2008 | 10:25 PM
07fitsport's Avatar
holy purple pulley batman...let us know how it goes how hard is to install and
also what seat of pants diff it makes
Old Jun 18, 2008 | 11:59 PM
Sugarphreak's Avatar
Push My Button
I am installing mine pretty quick, my gun has about 250lb so hopefully it is ok. Don't have that tool, going to try and have it in gear with somebody standing on the brake (engine off of course). My gun winds up a lot before it punches, the sudden impacts hopefully will mitigate the fact I don't have the crank tool. Also going to make sure the engine is nice and warm before I start.
Old Jun 19, 2008 | 12:57 AM
Giggles's Avatar
I want one
Old Jun 19, 2008 | 01:12 AM
Diy Done!!
Old Jun 19, 2008 | 11:08 AM
Push My Button
Love'n the paint sketch!
Did you just hit the crank pulley bolt with an impact gun or did you do anything else to take it off?
What did you have to do to get access to the crank?
Old Jun 19, 2008 | 09:46 PM
I tried REALLY hard on that picture!!! Thanks for noticing!
I just used my Mac Tools 1/2 drive impact gun.
All i did was take the 3 clips out from the plastic cover piece on at the right front wheel.
Old Jun 20, 2008 | 09:26 AM
07fitsport's Avatar
where did u get the pulley from and how much??
Old Jun 20, 2008 | 09:32 AM
07fitsport's Avatar
most charts and dyno i seen on the FIT has most hp pickup around 3000 rpm
Old Jun 20, 2008 | 01:44 PM
From AJ Racing. It's on special right now in the AJR forum, $195 i think.
Old Jun 20, 2008 | 07:08 PM
jezzy's jazz's Avatar
another great diy from fit of rage, thanks dude...
Old Jun 22, 2008 | 01:01 AM
feifei's Avatar
got mine installed yesterday...i agree what Fit of Rage was sayin but i do feel a little different after 3000rpm....im happy with it as well
Old Jun 22, 2008 | 01:51 AM
Push My Button
ahh fudge... all that work getting everything apart only to have my impact gun FAIL at getting it off.... I knew Karma was going to get me for laughing at Xorbe My gun is rated at 250ft/lb.... yikes
Old Jul 18, 2008 | 08:41 PM
ericman20's Avatar
You feel anythign different under 3000 RPM??
Old Sep 28, 2008 | 04:22 PM
Hondasforlife's Avatar
so its done its job? what does it actually do or suppose to do..also will it fit on the AT FIT? thank you men
Old Sep 28, 2008 | 04:34 PM
It does it the AT's. Mine is AT. As for performance gains, i dont' really feel anything. All it's really going to do is make it so that there's less rotational weight, therefore, it's easier for the engine to make it's power and turn faster.
Old Sep 28, 2008 | 06:15 PM
was it worth 195 in your opinion
Old Sep 28, 2008 | 06:19 PM
because i didn't dyno the car before and after, i can't say "yes" or "no"
