View Single Post
  #1 (permalink)
Old 04-25-2006, 04:39 AM
AJ PwR Jr.'s Avatar
AJ PwR Jr. AJ PwR Jr. is offline
Premium Honda FIT Vendor
AJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to live
Send a message via AIM to AJ PwR Jr.
Reason for JDM Header not fitting !
I have receive PMs from a few memebers here asky me "why the JDM header will not fit" Here's the reason.
Left : stock header (size 28mm) vs Right :JDM aftermarket header (32mm)
The stock USDM header has a O2 bung to fit in the O2 sensor !
Where is the O2 bung on the JDM after market header
The header will bolt up just fine but if you seriously want to fit any brand JDM header then you will need to drill a hole and weld on the O2 bung. You have to make sure the O2 sensor aligns properly because if the sensor stick too far in or out, it will affect the reading to the stock ECU.
Thanks
Ben
__________________
A&J Racing International
#155-1991 Savage Rd
Richmond B.C. V6V 0A4
TEL: (604)279-0329
Email: info@aj-racing.com
URL: www.aj-racing.com
Your JDM parts and Honda Tuning Specialist
Sponsored Links
