Thread: offset question
View Single Post
  #14 (permalink)
Old 06-23-2008, 10:58 AM
jim@tirerack jim@tirerack is offline
Premium Honda FIT Vendor
jim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to livejim@tirerack relies on Rep Points to live
If you were to stay with a 55mm offset wheel and the wheel is wider than stock they would then rub on the inside. The offset has to be adjusted so that some of the extra width is distributed toward the fenders.
__________________
Jim@tirerack.com
800-428-8355 ext 364
Performance Specialist
