Quote:
Originally Posted by eldaino
aj: what speeds where you going that the dampers made the car feel like it was unstable? was this on only the second or 3rd adjustment? will the camber bolts be necessary even for a daily driver?
i like the fact they they are comfier than stock on the lowest setting...but do they PERFORM better than stock at this setting?
It felt unstable when I was taking a long sweeper at around 100-110kph. I did the road test on the day that the damper kit got installed. SO there might be a difference after alignment is done with more negative camber achieved.
Yes camber bolts is necessary. It does make quite a bit of difference no matter all u do is daily driving or sports driving. Camber bolts for Fit are cheap anyway.
