View Single Post
  #206 (permalink)
Old 06-27-2008, 12:31 AM
e-revs e-revs is offline
e-revs is on a distinguished road
Honda Fit 2007
Honda Fit 2008
Front Strut Bar
Every vehicle’s front chassis is different; therefore designs and develops the front bars based on the actual conditions of the vehicle, repeatedly testing and proving to its perfection. High attention is taken during the design and development stage to ensure the chassis is able to withstand the load when a bar is being installed.
Ultra Racing is proud to bring to you the first of its kind in the country, the MULTI-POINT Front Strut Bar. The Front Strut Bar is installed to minimize the weight transfer of the vehicle body, therefore the vehicle will not loose traction easily during cornering.
Honda Fit 2007 Front Strut Bar
Honda Fit 2008 Front Strut Bar
Rear Strut Bar
The Rear Strut Bar is particularly useful for an FF vehicle. The Understeer behavior can be corrected by stiffening the rear chassis by installing a Rear Bar.
High attention is taken during the design and development stage to ensure the rear chassis is reinforced and strengthened in a proper way that it will not cause the vehicle body to undergo too much stress.
Rear Upper Bars is designed for vehicles with high roof and high CG (Centre of Gravity) such as MPV's, mini MPV's, SUV's and Hatch Backs.
Initially, Rear Upper Bar is invented specially for the 5 Doors Hatch Back cars. The 5 Door Hatch Back cars have weaker rear upper body due to their wide opening rear door. Under extensive investigation and actual road proving, it corrected the shortcoming of the vehicle’s swaying rear upper body.
Honda Fit 2007 Rear Strut Bar
Honda Fit 2008 Rear Strut Bar
Lower Arm Bar
The Ultra Racing Lower Arm Bar is designed to reduce the flex of the vehicle chassis where it is connected by the Lower wishbone of the suspension system, thus to lessen the distortion of the vehicle lower suspension when it is under load, especially during hard cornering. It is installed at the lower mounting points between the left and right suspension and the vehicle chassis. Tremendously improving the stiffness at the area where the lower arm is connected to the vehicle chassis. The Ultra Racing Lower Arm Bar also keeps camber accurate during hard cornering.
Honda Fit 2007 Front Lower Arm Bar
Honda Fot 2007 Rear Lower Arm Bar
Honda Fit 2008 Front Lower Arm Bar
Honda Fit 2008 Middle Lower Tie Bar
Anti Roll Bar
Anti Roll Bars (also known as anti-sway bars, sway bars or lower tie bars) affect the handling of the car on the lower end of the suspension. Sway bars tie the lower suspension components together across the front or back, and affect a car's over steer and under steer. Sway bars will keep your car flat in turns instead of leaning over to one side. They distribute energy from the side of the car with all the force from the turn on it to the other side of the car, bringing the whole car down flat instead of leaning to one side. Of course the car will still lean some, but not as much. Sway bars provide better cornering especially at high speeds and work very well in conjunction with strut tower bars. However, they can have an adverse affect in off-road situations by leaving one tire completely off the ground.
Honda Fit 2007 Rear Anti Roll Bar 16mm
Honda Fit 2008 Rear Anti Roll Bar 16mm
If you guys are interested in the strut bars for the Fit 2007 or Fit 2008, i can do a group buy for your forum members. Let me know how the response. Thanks and have a nice day.
