What do you do..
Old Jun 30, 2008 | 03:31 PM
MemphisFit's Avatar
What do you do..
..... To keep your MPG's up? im open to any and all suggestions.
And what about those vortex things you can put in your intake hose. do those really work?
Old Jun 30, 2008 | 03:35 PM
SD_MR_FIT's Avatar
the vortex things dont work at all.
well i have a CAI. that helps out a lot. shift at 3k city driving
i cruise control it on the freeway at 60mph.
i keep up with maintenance.(oil @3k, sparkplugs at 15k, clean air filter every oil change,)
uh...just drive like a 90 yr old person that cant really see..so they have to drive slow.
Rod2Rice's Avatar
Any gadget you see advertising MPG gains is a load of bull. best way to keep them mpg up is the way you drive. Be easy on the gas pedal.
Old Jun 30, 2008 | 03:43 PM
JDMchris.com's Avatar
I run THIS
Try getting a scangauge. From what I hear it is the best investment to adjust your driving habits to get optimal mileage.
Old Jun 30, 2008 | 05:20 PM
yah, per solbrother he recommends the scangauge2 too.
i should have one later on this year... i want it mostly for intake temp
though...
Old Jun 30, 2008 | 05:55 PM
bonsaikc's Avatar
You are WAAAAAAAAYYYYYYY overmaintaining your Fit. The Maintenance Minder really does work, you should think about it. Honda oil is a synthetic blend, you are wasting your money changing it at 3000 miles. Also, you are wasting money on spark plugs. These are platinum tipped and designed for 100,000 miles.
I check my dipstick every tank, and have been adopting some hypermiling techniques. At the very least, inflate your tires to the sidewall rating (51PSI) and engage the clutch to coast downhill on the highway.
Old Jun 30, 2008 | 06:00 PM
kancerr's Avatar
we have rules on hypermiling/over inflation yet(its not worth over inflating your tires for daily driving)? ;/ haha... no offense to you bonsaikc, just difference of opinions. scanguage is a good investment. so is takin it easy on the car...
Old Jun 30, 2008 | 06:02 PM
Burbio's Avatar
that's a great way to kill gas mileage. leave the car in gear and take your foot off the gas. DO NOT ENGAGE THE CLUTCH OR SHIFT INTO NEUTRAL. as explained on Top Gear, leaving the car in gear while coast uses NO FUEL, but coasting in neutral forces the car to feed gas into the engine to prevent it from stalling.
i coasted in gear and accelerated very conservatively with the tank i'm on now, and i'm at 350 miles with the gas light just coming on today. mind you my fit is AT.
Old Jun 30, 2008 | 06:32 PM
kancerr's Avatar
yeah burbio is right. i think some members on here have proven it with scanguage also...? ive read this in several posts on FF. keep it in gear when coasting if you wanna save gas...
Old Jun 30, 2008 | 07:53 PM
kndlewis's Avatar
Stay off the brakes. Get off the gas sooner so you don't need the brakes to go around the corner. You'll find many examples where a little bit of planning (thought) will help you use the brakes less.
Every time you use the brakes you lose the momentum you just paid for.
Old Jun 30, 2008 | 08:13 PM
KCHoosier's Avatar
Drive barefoot
I heard this on NPR a couple of weeks ago, among other things. The slower you accelerate, the better.
'Hypermilers': Squeezing Out Every Mile Per Gallon : NPR
Here is their bullet point list, some don't apply to a Fit (Don't Tow, Don't use 4WD):
• Don't use quick accelerations or brake heavily.
• Don't idle excessively.
• Don't drive at higher speeds. This increases wind resistance and mechanical friction, which reduces fuel economy.
• Frequent short trips reduce fuel economy, since your engine doesn't operate efficiently until it is warmed up.
• Remove cargo or cargo racks, which increase aerodynamic drag and lower fuel economy.
• Don't tow unless absolutely necessary.
• Minimize running mechanical and electrical accessories, like your air conditioner.
• Avoid driving on hilly or mountainous terrain if possible.
• Don't use four-wheel drive if it is not needed. Engaging all four wheels makes the engine work harder.
• Park your car face out, if allowable, so you don't have to back out of the space and turn needlessly.
• Minimize having to stop at red lights by scanning the road far ahead and preparing to slow down well in advance.
Old Jun 30, 2008 | 08:20 PM
mahout's Avatar
I keep my tire pressure up at 44 psi on 205/40x17's on 7" rims;you probably only need 36 psi on 195/55x15's on 6" rims. If gas milegae gets to be critical I'll go to 175/65x15's at 42 psi. Reduce rolling friction. My 175/65x15's increase mpg by 2 to 3 mpg.
And I use sport mode to shift myself rather than computer; saves lots of downshifting to higher rpm gas consuming.
Old Jun 30, 2008 | 08:21 PM
Firebat666's Avatar
i agree with getting a scangauge, i just ordered mine and from what i have read it will help you adjust ur driving style to get uber great mileage, till i get my scangauge, i simple accel smoothly to 3K and shift and dont exceed 60mph... im averagig 36-37 mpg, im hoping scangauge will help me get 40 mpg! lol
Old Jun 30, 2008 | 08:54 PM
solbrothers's Avatar
scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge scangauge
Old Jun 30, 2008 | 09:57 PM
MemphisFit's Avatar
Talking
ok thanks for the help ther guys. ok another question.does it hurt your gas mileage to have cruise control engaged while cruising at speeds in which Vtec is open?
Old Jun 30, 2008 | 10:00 PM
it hurts your mpg to use the cruise control
Old Jun 30, 2008 | 11:03 PM
Burbio's Avatar
i don't know about that... everything i've ever heard says CC will improve mileage. but you have a scanguage, right? what's the difference in mileage between CC and no CC?
Old Jun 30, 2008 | 11:14 PM
with cruise control i get 39ish mpg coming home from work. set at 50mph. with using my foot, i get 45+mpg. same speed. today i got 50mpg. my personal best
Old Jun 30, 2008 | 11:20 PM
Burbio's Avatar
good to know...
Old Jun 30, 2008 | 11:31 PM
you mean scangauge2, no?
