out of the 2 choices above, try the 15x6.5 +40mm.
yes, 2mm does make a difference because it only takes 1mm or less
to rub.
the other issue is, often times these wheels made out in china or
watnot do not have the best dimensional tolerance. they may
say +40mm, but in actual dimension may not be.
tires.... 195/50/15's for sure if you're going to lower your car.
it not only gives better clearance from rubbing, it also looks
waaay better, and have a bit better gear ratio for acceleration.
__________________
08 FitSport Storm Silver Metallic (5MT)
Suspension: EnduraTechs
Dressup: Black fog lamp surrounds, Megan axle-back.
Wheels: DragDR21 15x7 +40mm, Ziex912 195/50/15
Int & Ext: Factory a/s floor mats, Zeta deadpedal,
factory trim kit, JDM visor, JDM door handles, MOMO Champion,
Daikei hub 20mm spacer + AS01 adjust, RecaroYoung Sport
child seat VivoLite, TypeR style satin shift knob, Zeta cargo cover,
Mugen window visors, ONYX metalized 30% tint.
ICE: JVC Arsenal HU
