WR Intake Manifold EGR problems Solved.
Old Jul 17, 2008 | 05:10 PM
WRLEO's Avatar
After Extensive testing we have finally solved the problems with the EGR Port on the Intake Manifold.
Testing with the New Innovate LM-2 and extensive testing on road monitoring the EGR, we have come to the Conclusion of adding a Threaded Barb Fitting on the Manifold where the EGR Fumes come off the Cylinder head and then needs to be re-routed back into the system, instead of back into the manifold.
We are threading the manifolds and adding a Vaccum Cap for the Port on the Plenum, which can be later used for a Vaccum Source for Boost gauges or Air Temp, Etc...
Here are the pictures..
Old Jul 17, 2008 | 11:39 PM
Sugarphreak's Avatar
Push My Button
Nice job guys
I have been running mine now for a couple of months, other than the car throws the "low EGR flow" code (which does not affect the performance) this is a pretty fantastic product.
With this fix in eliminating the engine code I would highly recommend it to anybody who wants to get some more power out of the car. Be it supercharged, turbo or Naturally Aspirated (such as myself) it is easily worth the cost with the performance it delivers when compared to other products. I will say it has had the most dramatic power adding impact on my car.
I will be upgraded to the revised manifold once we figure out a shipping method. WeaponR has really come through with their customer support for me, I can't say enough nice things about them!
Old Jul 17, 2008 | 11:51 PM
Fit of RAGE's Avatar
what were your gains by the way "Sugarphreak"?
Old Jul 18, 2008 | 12:03 AM
Push My Button
I haven't done it yet I know, I know... I am way behind on it. When I was down there Ben said he thought I would put down between 110 and 115whp.
I still have a UR pulley set sitting in my closet, hopefully that goes in next week sometime. I am also still teetering on getting a test pipe as well, but I think I might pass unless a good deal comes up.
I am going to start seeing if Illusive wants to go in with me and do a couple of dyno runs to compare this month. In any case I want to dial in my setup as well with some dyno tuning. I would just be throwing away money on tuning if I do it ahead of installing those parts.
I am looking at doing it on a mustang dyno as well which generally reads a bit lower. On this one specifically a 108hp civic puts down 81whp. I would expect a base fit to put down maybe 80-85whp on this one.
Old Jul 18, 2008 | 07:57 AM
coupdetat's Avatar
Wait, so does that mean there is no CEL anymore? Are there any other drawbacks to this product?
Old Jul 18, 2008 | 09:00 AM
WRLEO's Avatar
NO more CEL lights..
Old Jul 18, 2008 | 10:24 AM
Push My Button
^^^ No drawbacks
Old Jul 19, 2008 | 09:16 PM
leonine's Avatar
so are all connections taken into account. meaning that all of the existing hose and sensor connections are still used?
Old Jul 23, 2008 | 08:26 AM
alf74's Avatar
Is there anyone who can sold me original intake manifold? Thank you
Old Jul 23, 2008 | 10:41 AM
Push My Button
Yep, everything is accounted for
Old Jul 23, 2008 | 12:54 PM
CTmatt's Avatar
i'd love to see a pic of that in the car. mmm.
Old Jul 23, 2008 | 02:20 PM
Tofuman's Avatar
this looks nice. with a CAI, header and exhaust would this require an air/fuel controller so the car doesn't run too lean?
Push My Button
ask and you shall receive
Yeah you have to do something or the mix is so far off you will loose power. At AJR Ben was saying the car ran like crap afterwards until they tuned it for the manifold. WR has a fuel computer for a pretty decent price. With mine I choose the route of E-manage Ultimate so I could fine tune it a bit, that was a bit more expensive but the results are great. You could probably fine tune with the Blue or and AEM solution as well. Not sure if Apexi Neo would work too.
Old Jul 23, 2008 | 02:40 PM
CTmatt's Avatar
NICE. verrry nice.
Old Jul 23, 2008 | 02:47 PM
Tofuman's Avatar
apexi neo looks nice, i wouldn't mind using it. is the e-manage ultimate difficult to tune with? i would probably take it to a professional shop, but just curious.
Old Jul 23, 2008 | 03:10 PM
Push My Button
If you are going to put the money out for an E-manage Ultimate, I would say it is better to have somebody who knows what they are doing to tune it to maximize your performance and efficency. It will cost you about 200$-ish but then you don't need to buy the wideband sensor. I am also lazy
The best tune you can get (or so I understand) is a dyno-tune, usually about the same price but you get a dyno graph and more precise tune out of it.
Old Jul 23, 2008 | 03:21 PM
Tofuman's Avatar
yeah, i would probably bring it to church automotive. they have a flat rate available for the e-manage of $325, but they're supposedly the best tuners around.
Old Jul 23, 2008 | 09:27 PM
leonine's Avatar
the pic looks sick! did you drive it before it was tuned with e-manage? when you say it ran like crap can you elaborate please. i was hoping to get this and keep the supercard (at least for now) that comes with the KWSC but if it will screw up my idle or closed loop a/f then i will have to wait.
Old Jul 23, 2008 | 09:40 PM
WRLEO's Avatar
I havent seen it run like crap because when we made this intake manifold we didnt have a fuel solution. It ran fine.. but was alittle lean.. Which helped save gas.. ahahah
It was not dangerously lean.. it was around 14.5-14.8..
With the fuel computer we offer it allows the engine to run at 13.8-14.0 which is optimal..
All connections are accounted for and will NOT throw a cel now..
Old Jul 24, 2008 | 12:22 AM
Push My Button
^^^ On my car I was running a cold air intake, header and full performance exhuast system. We found the wideband sensors said it was running way too lean, enough out of whack it was actually loosing power. If you are running a decent I/H/E config I think the fuel computer/engine management is a must.
I would suspect that if you were to install this unit on a stock vehicle it would run a bit lean, but within a reasonable tolerance.
This rule applies to test pipes as well, if you run an I/H/E setup with a test pipe your car is probably running too lean.
I didn't drive it un-tuned. Ben from AJR took it out to tune it on the fly, he basically said that without the tune it wasn't running well and basically was losing power until they tweaked it.
That supercard was making Illusives car run way too rich with the upgraded injectors. He was actually getting CEL's from it running too rich, I would say the Manifold will only help that
Looks like we are setting up a Dyno for next month; MR_ET (stock) VS my fit VS Illusive (KWSC) VS YeeFit (T1R Turbo @ 6psi) all on the same dyno machine. Should give a nice idea where everything stands. Plans are in the works, more details to come later on.
