View Single Post
  #256 (permalink)
Old 07-28-2008, 06:47 PM
pcs0snq's Avatar
pcs0snq pcs0snq is offline
pcs0snq has a spectacular aura aboutpcs0snq has a spectacular aura about
70's way too fast, unless you have to do that for some reason. Slow the pulse down to 60 or less if you really want to see some numbers. Also, if you want the next step, FAS kill the eng and coast then restart to start the pulse.
I'm not an expert on the hill deal as I just have over passes. That said I have talked to the experts and the recommendation on that is to try and time the glide to the down hill part. For me that means holding a speed till you crest. That speed should be maybe 5 under the peak.
Quote:
You may need to set the tank size a little larger, as the Fit's tank can actually hold between 11 and 12 gallons. As for the 9999 thing, that is normal while you are coasting or braking, but not otherwise.
I know that. but thanks
__________________
Paul
2008 VBP Fit Sport Man 5 spd trans
208US Gal saved in the last 20,000miles
