Staggered front tires?
Old Aug 2, 2008 | 08:57 PM
mahout's Avatar
Originally Posted by bluerice
I was wondering if anyone has tried running staggered front tires, as in wider front tires than in the rear.
I know that the J's Racing Fit GT run 225's up front and 195's in the rear, but that car has a massive K24A in the front and a completely stripped interior.
So I was wondering if there's anyone that still uses there car as a daily driver and has staggered front tires, and if anyone does how are the handling impressions with the staggered tires?
Although we don't use differing tires on our Fit we've been doing it routinely for 25 years on racers and A/X'ers to improve lap times.. And it has always worked.
There are 2 major things to bear in mind:
1. The front tires should be one size larger (depending on HP) than stock and slightly smaller in diameter so the greater weight of the tire is at a slightly smaller radius to keep the torque required to turn the tire about the same as stock and therefore doesn't eat any power.
2. The rear tire diameter should be slightly larger than the front tire and one size less cross section than stock, again depending on HP and weight distribution to prevent the hobby-horsing that occurs on FWD when the rear wheels are smaller than the front.
Lighter wheels are beneficial of course but not part of these considerations.
Here's an example we did recently:
A FWD car with 225/45x17 tires (24.97") improves lap times by substituting 235/40x17 (24.40") fronts and 215/45x17's (24.61") at the rear. Lap times improved by 5%. Another is on the way.
An example of this can be seen on you tube's 'hyundai sundae..". The Azera in the video is equipped with Pirelli M+S 245/45x17 front and 225/50x17 rears. The Azera is a family crusier unprepared in any performance upgrades except lowered front springs and performance rear shocks. Handling on a street vehicle doesn't get much better than that.
PS we have never found any benefit from mounting wider rear tires on an FWD vehicle. Neither have performance manufacturers; the wider tires are always on the driving wheels.
PPS as long as the tires are close to same diameter and the wheels are the same dia there is no difference in appearance. Can't tell unless you actually measure them.
good luck.
Old Aug 2, 2008 | 09:11 PM
mahout's Avatar
I guess I should've said what sizes i was thinking of.
I was thinking to start off with 205/50R15 in the front on 15x7 +43 offset wheels and 195/50R15 in the rear on 15x7 +38 offset wheels.
And then if I like how the staggered fitment feels maybe try 185/55R15 in the rear on 15x6.5 +33 offset wheels.
That way atleast from the side profile it'd look like the tires are the same size.
The 205/50x15 and 195/50x15's are a good choice.
Old Aug 2, 2008 | 09:16 PM
mahout's Avatar
well i don't think my car really needs too much, depending on the corner and the slope sometimes the car understeers and sometimes it oversteers, I really just want to get rid of the understeering.
Very easy and doesn't cost a dime. Just disconnect the front antisway bar and tether out of the way. A Fit has soooo much understeer its ridiculous and without the ASB its pretty good handling car.
Or you could add a rear ASB but that dorsn't help track manners gets too tipsy.
Old Aug 21, 2008 | 05:22 PM
mahout's Avatar
=) Ok I have another question, I had come to a conclusion that I was going to run 205/50R15 on 15x7 +43 wheels on the front and then 185/55R15 on 15x6.5 +35 wheels on the back so that i have wider tires on the front while still having the side profile of the car look the same, although recently I realized that if I ran this set up that eventhough I'd have wider front tires, I'd also have a wider rear track compared to the front with the wider offset rear wheels, and so I was wondering if I ran that set up having wider rear wheels would that defeat the purpose of having wider front tires or should I run the same offset wheels all around or possibly even wider offset wheels in the front?
Run the wheels that fit the approved rim width range for the size tire you are running. Wider wheels at the rear may or may not help, depending on your tire pressures. Having a little higher pressure rear helps decrease understeer, as Honda mentions doing on the 09's, not once but twice.
But more traction at the front is mandatory.
Goettler
60
Jun 29, 2016 10:41 PM
ezduzit
Jun 19, 2008 04:30 PM
fitdc
Jun 10, 2008 12:31 PM
Apex77
Aug 30, 2007 04:32 PM
piperspost@webtv.net
May 10, 2005 11:42 AM
