View Single Post
  #83 (permalink)
Old 08-03-2008, 11:47 AM
ToFit2Quit ToFit2Quit is offline
ToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to liveToFit2Quit relies on Rep Points to live
Quote:
Originally Posted by LizardKing View Post
My mechanic told me the gurgling was because there was air in my coolant lines due to a very small leak. However, the dealer said there was no leak and it was due to the gas tank. Who really knows what's going on with my Fit....
If there was a leak you will know. You will loose coolant and will see the residue all over your engine. Also, any leak in the radiator will spray out since it's under high pressure when hot. I think you might just have air bubbles in your radiator.
__________________
The Fit is GOLD!
