View Single Post
  #31 (permalink)
Old 08-05-2008, 12:30 AM
scroogie scroogie is offline
scroogie is on a distinguished road
Quote:
Originally Posted by manxman View Post
The clamping cams on the Thule are pretty stiff, but you only have to set them once. After that, all of the adjustments are done with the bolts. If you had invested a few bucks in either a bar clamp or Channel Locks slip joint pliers at your hardware store, you would be using your rack right now and would have the tool or tools for other uses the rest of your life.
My husband helped me install my thule rack and we first used a "C" clamp and a ruler to tighten the cams. after we did this several times (it kept slipping off center) my husband got a long bolt the same size as the hole in the cam and screwed it in and that made the job soooooooooooo much easier it was rediculous. Granted they had ben set at least once by then but i could use the bolt and do it. It does help having a farm shop full of tools at your disposal when doing this kind of stuff. Thule could include a bolt just for this reason and it would help.
