View Single Post
  #1 (permalink)
Old 08-09-2008, 08:55 PM
Fit of RAGE's Avatar
Fit of RAGE Fit of RAGE is offline
Honda Fit Forums Moderator
Fit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to liveFit of RAGE relies on Rep Points to live
DIY: T1R Sway-Bar
As usual, AJR, Fitfreak.net nor I (Fit of RAGE!) is responsible for ANY damages, problems to your vehicle. Please be EXTREMELY cautious and
perform this mod at your own discretion.
I kinda got carried away and ended up in "the Zone" when i was doing this so it's kinda a crappy DIY Anyway,
1) Purchase sway bar
2) Personally, i felt that taking the cat out is VERY useful, so remove cat
3) disconnect the sway bar from the link kits. You'll need an Allen head AND a 12mm wrench.
The reason you need to do this is that if you just use a 12mm, the link kit will most likely spin and you'll never get the bolt off.
4) support the vehicle front AND back as you'll need to drop the engine/tranny cradle a little
5) Unbolt the lower control arm. There are 3 bolts. two shown here and one in front.
6)
7) Now, unbolt the cradle from the car. there are 4 bolts in total. (two were from the control arm)
8) Unbolt the hold down bracket for the swaybar and lower the engine/tranny cradle just enough to get the swaybar out
9) Now, reverse the order. Make sure that you lube up the bushings REALLY well!!!
Sponsored Links
