Horrible smoky/acrid smell in cabin
Hey, I'm a newbie here. Seems like a great site. My questions concerns a horrible smoky/acrid smell that started a few months ago in my wife's '08 Sport with only 3,500 miles on the ody. It makes me sick. If I open the windows, or use the AC it goes away, but as soon as the car sits for a few hours the smell is back with a vengeance. This is not the usual AC moldy odor, or sweet heater core odor. Have scheduled an appointment for Monday at my Honda dealer, but I expect the usual, "Cannot duplicate problem" on the work order. I was wondering if any other member has had this problem and can pinpoint the source so I can give the service writer a heads up.
recall?
I doubt that this is the problem but there was a recall on a small wiring harness under the driver's floor mat. On an 08 that new I'd almost think the factory or dealership would have taken care of it. It might not hurt to ask the dealership if this (the only one I know of) recall service had been performed. It was reputed to potentially cause fires so an acrid odor isn't too much of a long shot. It's a shot in the dark but this problem is weird and very "unHondalike".
Can you pinpoint at least an area where the odor seems to originate or be the strongest? Seats? E-brake? Dash? It wouldn't seem to be wires burning or shorting if you say it gets stronger when the car isn't being driven. Any possibility something spilled inside the car? Have you tried removing the mats to see if they are the problem? If you were in my city I'd come over and sniff around - I've got a sensitive nose and can usually find the source of an odor. Good luck, but try to give the service writer more information. There's obviously something wrong, so they can't just blow you off, but they might say they can't find the source.
Did this happen just after deicing? You either didn't shut down both engines during deicing, or the line guys shot the deicing fluid into your APU inlet. That fluid smells horrible when it gets into your bleed air. Next time show them where not to spray.
That, or it could have been a compressor wash without the post wash engine run to dry out the bleed air ducts. I've seen a couple of air turn-backs, and aborted takeoffs due to this.;)
We talking about planes or a Fit? This post totally baffles me!
My VBP has that smell whenever it hasn't been opened in a while and that has been going on since the 2nd week of July. But if it is a recall I'm not taking it in till it is actually official otherwise I'll continue driving with the windows down all the time.
If it smells bad from start-up (engine and exhaust cold), then it probably isn't something stuck on the catalytic converter or muffler.
Sniff around under the driver's side dash. The fuze box is there so a lot of electrical wires run in that part of the vehicle - could be a short of some kind.
The next place I'd check is near the belts and rotating parts on the engine. If something is rubbing against one of the pulleys it might create a noxious odor.
It would definitely help to try to narrow the area of the smell. It isn't coming from the vents, any other areas you've ruled out?
Hey, Hootie!
I was going to put-up with the smell because of the cargo capacity and the mpg.
When I received my car last week and it did NOT have that smell, I was very pleased.
I wonder, when did your odor first start? Is your Fit newer?
(24 mpg because of a lot of no motion idling : )
Took the car in this morning. The service manager told me it was probably "new car smell". Right. What was he smoking? When I got in the car it smelled like a funeral home. I immediately went to the service manager and he told me he sprayed some Honda approved anti-bacterial spray in the HVAC vents--no charge. They also did the recall. Well, after almost 9 hours now there is no horrible smoky smell anymore. Time will tell if the recall did the trick, or the spray.
Was the car sitting around for a bit? It's not uncommon to get rodents who take up home in the engine bay, sometimes even in the car itself and it's very often that they can die while in there, especially if in the engine bay itself due to the heat. Poke around a little bit in there see if you can't find anything.
