Bisimoto Cold Air Intake
In the video posted below, Bisimoto has a cold air intake. Has anyone tried this, tested this? It's an older video posted for when they dyno'd the Bisimoto exhaust. I haven't seen any threads posting or asking questions about the intake.
I really want this set up for my new ride. That exhaust is nice. I like the low grumble without being a typical fart can exhaust. The 10 hp increase with the exhaust and CAI is not too bad either.
Even more interesting is that the power wasn't dropping off at 6500rpm either.
I've had mine for quite a while now and I like it, but I wouldn't want to do any long distance driving with it. At least without ear plugs. It resonates like mad. It sounds great though. No metallic, raspy fart ripping.
It would be better if it utilized both insulator mounts. It swings side to side slightly and really hard right turns it will rattle on the heat shield. It won't work with a receiver hitch without modification.
when i do hard cornering with it, it doesn't rattle with the heat shield. I noticed that when i installed it with only one bolt, it will do that. You have to tighten both bolts to keep it from rattling around. Also you have to get the hanger on the rubber mount in the exact position so it won't swing. Mine looks like it's been stretched and it is staying on just fine after 3 months with the Bisimoto. I agree it sounds so awesome... almost Racecar. My friends in the CRX's sound louder but it does the job. I can actually hear the car now.
FitLover55
06-30-2018 11:32 AM
Mikeyk12
04-24-2013 11:48 PM
romanc333
06-05-2008 02:07 PM
