Projector headlight install
#41
dude awesome job man.. I got the retro done for my ge and I've been saying from the beginning that this is one of the best upgrades to do on the fits!!!!!!!I will never go back !!!! i love it!!! I was actually trying to see if and how would it work out to use the new LED headlights that come on the acuras and toyotas now in days.. but back to the topic awesome job man looks great! I too used the retrofit source and got the fxr state 3 kit 4300 with the apollo 2 shroud... good job man.. I hope more people read up on this post and get away from the cheap hid kits that are out and understand the true function of it .. kudos to you my friend
#42
Im wondering if you have to trim the top and bottom of the shroud or did you trim the top more? I want to know because if the top and bottom needs to be trimmed I would just get the Apollo 2 flat shroud. Please let me know.
#43
Yes, I removed the clear diffusers and painted the reflectors black. The Vled’s are so bright that they work fine without a reflector. I used semi-gloss paint which still gives a decent amount of reflection, not that reflection is needed. I still need to hook them up so that they dim 50% at night as they are actually too bright at night for someone in an opposing lane. The Xenon’s are TRS Bi-Xenon Morimoto Mini Stage III DS2 with 4300k bulbs. The LED’s are V3 Triton. The V3 switchbacks plug directly into the factory turn signal harness. I don’t have them running as DRL yet. I need to hook the positive to an ignition source for that to happen. Just haven’t got to it yet.
The V3’s were $145 and the Xenon kit was about $320. I bought the V3’s directly from Vled and the Xenon’s directly from TRS.
5K WHITE AMBER SWITCHBACK V3 TRITON LED SYSTEM | 1 PAIR - Switchback - Bulb System - V3 Triton
Bi-xenon Morimoto Mini Stage III Kit (D2S)
For your Blinker running as DRL have you thought about running a HOT wire with a male connector to the positive side of the Fuse #25 for DRL. You can use a test light and see which side positive with the engine on. =)
#44
I had to trim the top and bottom of the shrouds.
I'm assuming fuse #25 is powered only when the daylight sensor senses light and therefore the LED's wouldn't be on at night in that case. If I can wire to an ignition source they will always be on as long as the car is running.
#45
Love the look of the blacked out headlights!
I am currently waiting on parts to be delivered to do a retro on my GE.
Did you know about the Mini Gatling shrouds? They are supposed to be smaller than any "average" shroud out there and made specifically for the H1 and D2S projectors. I know it's too late for you but this might be good info for others that will be doing retros.
Also, The Retrofit Source sells the adjustment screw things that stripped out on you. Again, prob good info for other people, lol.
#46
I don't see a option for the mini gatling shroud for this kit maybe it doesn't fit? Im thinking to get the appollo 2 flat shroud so I don't have to do too much trimming. What are your thought on that?
#48
Actually they are the flat shrouds appollo 2.0, flat on top and bottom and is cricle. Im not sure if that's gonna work unless the projector fits right in the middle. But on Superfly picture it looks like he trimmed the top more than the bottom.
Apollo 2.0 - Projector Shrouds from The Retrofit Source Inc
#50
Cutoff is good, I need to adjust the drivers side up a little this evening but that's it. I'm not used to the slopes in the cutoff, if that's what you want to call them. My explorer had HID but I never noticed any defined slope like that. There is quite a bit of purple hue at the edge of the cutoff when I see it shining on the back of a car in front of me or something like that. I guess that's normal???? Otherwise the light output looks good.
I don't think I'll change bulbs unless one burns out. Yes, they are the newer XB35 Morimoto bulbs.
I just finished installing the projectors in the headlights. The Apollo 2 flat doesn't need trimming. I know what you mean by the cutoff slopes I was surprised about this. I don't think this is normal because I had cars with projectors and the cutoff was straight throughout. I'll post up some pictures when I get the headlight adjusted.
#55
just wanted to confirm, but the D2S kit w/ flat Apollo 2.0 shrouds don't need to be trimmed at all? do you have any pics?
#56
I got the Moto control box and the 5five ballast. One thing I need to mention and its pretty scary is that when using autolgiht while driving and the auto lights kicks on, my engine freaking cut off. One time I was driving up into my garage and as soon as I enter the dark part and auto light turn on the hid my engine completely died. Last night when I went out to pick up food around 6:30 going 35mph and the lights auto turn on my engine cut off but didn't die completely since I was going at a higher speed. I guess it dead but since I was going fast it jump started back up. This is pretty scary since I drive my kids around. I called retro source and Charlie told me It could be something with my car not with their HID and I ask him about the canbus relay and was told thats only for european cars and my car is japanese I should be good with the motocontrol. Also he told we to recheck my ground wire which I will do later tonight. Its funny because when I manually turn the hid on while car is running I got no problem, the only thing that is bad is auto light position is right before the manually so if I don't turn the lights on fast enough the auto light will cut my engine off if its dark outside. Someone please give me some input.
#57
Here is the photo
10734189_10202973653524124_3989228298011739599_n by johnny121010, on Flickr
1912144_10202973653724129_1043635461213081630_n by johnny121010, on Flickr
#58
Hi Tofu
I was thinking about adding a capacitor to the system. It would help my stereo AND I'd be willing to bet it would stop the engine cutout.
#59
Same thing happens to me. I have the 35w lights. I've noticed it's only when the ballasts are first energized for the day meaning when I turn the lights on in the morning or night for the first time. It also seems to be only if I turn the lights on right after starting the car. If I let the car run for 20 seconds of so and then turn the lights on it won't do it. Also if I drive, then stop somewhere, get back in the car after a few minutes it won't do it. Perhaps there are capacitors in the ballasts that really suck the energy when they're spent but if they've been on recently they still have enough juice for that initial firing.
I don't think a cap will help with this issue unless the ballast is power from the cap first. Do you think that maybe upgrade the battery will help? We need more input in this. I can't be driving around afraid of the dark and hoping my HID doesn't turn on while Im driving.
#60
