3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Cargo LED -Huge Improvement!
Old 08-02-2014, 08:00 PM
ADVphotography's Avatar
Hey All,
As you may recall in my last post https://www.fitfreak.net/forums/3rd-...bulbs-led.html the LED's I used didn't make a big improvement on brightness for the cargo area, although they were perfect for map, dome, and license plate. Well, I just got this one and its a HUGE improvement. $10 for a single LED was a bit steep but glad I sprang for it as it is much brighter, and has a pretty good build quality to it.
Bulb/LED/Circuit Board/Whatever-you-wanna-call-it used:
Amazon.com: LEDwholesalers T10 Base 10 SMD 5050 LED White Side Pin10-30V DC Bulb, 1438WH: Automotive Amazon.com: LEDwholesalers T10 Base 10 SMD 5050 LED White Side Pin10-30V DC Bulb, 1438WH: Automotive
**UPDATE 9/9/14** -This appears to be identical to the one used on Amazon: https://www.superbrightleds.com/more...edge-base/214/
Before:
After:
Backside of the board. As you can see it fits perfectly. No trimming needed.
LED's
Old 08-02-2014, 08:32 PM
Avus's Avatar
That's quite a dramatic difference.
Old 08-02-2014, 10:05 PM
BMO's Avatar
BMO
BMO is offline
Thanks for the new review! Your photos are super helpful.
Just added a bulb to my cart
Old 08-02-2014, 10:10 PM
ArchaicAP2's Avatar
This a no brainer with the pics provided & a must for everyone. Good job.
Old 08-02-2014, 11:21 PM
GeorgeL's Avatar
Just what I was looking for! All the LEDs pointing in the same direction!
Old 08-04-2014, 01:13 PM
chrisjones's Avatar
Nice work with the "How To", and great photos. An inexpensive, easy to do project with such good results is a no-brainer. My pack of LEDs should be in the mailbox this evening and the larger one for the cargo area is now on order for Wednesday. Thank you!
Old 08-04-2014, 02:44 PM
bedaz's Avatar
Could this bulb also be used in the dome light?
Old 08-04-2014, 03:12 PM
noripwr's Avatar
I actually saw a pic of it installed in the dome light somewhere while looking up LED dome lights on the Fit. So I think it would fit. I got a pair for the trunk and dome light to see how it goes.
Old 08-04-2014, 03:13 PM
dpmason's Avatar
Love it, just ordered mine.
Do they dim like the incandescent bulbs?
Old 08-04-2014, 11:00 PM
SheepNutz's Avatar
Yes they do.
Old 08-05-2014, 11:50 AM
TofuShop's Avatar
Excellent - waiting to see if this will fit in the dome also
Old 08-05-2014, 11:50 PM
It fits!! A little too bright for my tastes though so I moved it back to the cargo area.
Old 08-06-2014, 08:35 AM
chrisjones's Avatar
The smaller ones in the multi-pack that was listed in the first post in this thread is about right for my needs in the cabin area. I was looking for "a bit brighter" but not a lot because that once-in-a-while when a cabin light needs to be on just for a minute at night while driving (passenger drops something and needs to find it, or whatever) super bright is going to be a problem. Perfect, though, for the cargo area where you really want to see very well.
Old 08-06-2014, 11:06 AM
Mike Houser's Avatar
Mine arrive in today's mail for the cargo area...did the rest in the smaller bulbs..look great
Old 08-06-2014, 12:48 PM
TofuShop's Avatar
wow, tight fit! since you say it's too bright, ill save money and just order one for the cargo area. thanks for helping us all out
Old 08-06-2014, 01:42 PM
Buck Fitty's Avatar
Looks nice. In the cargo area, brigher is better! One mod I've made in my 2008 Fit is to replace the cargo area light with a switched cargo area light. So if I want, I can have the trunk open and the light off. Saves battery, and in some cases, I don't want the light on for other reasons.
I found that the cargo area light module for the Honda Odyssey was a direct drop-in replacement for the Fit, but the Odyssey module has a switch.
Old 08-06-2014, 02:27 PM
robbes's Avatar
Cheaper Source?
This bulb looks quite similar, but 5 for ~$7 and free shipping:
5 X T10 G4 Bulb Spot Light Lamp 5050 12 SMD LED DC 12V Warm - US$6.99
Old 08-07-2014, 10:23 AM
BMO's Avatar
BMO
BMO is offline
Installed mine last night-- purchased from the link the OP posted. Quick and easy, great results. Love doing these kinds of simple changes
Old 08-11-2014, 08:16 PM
TofuShop's Avatar
i just got mine and installed it. i LOVE how it's a pure white color and not blue like the JTech bulbs. i want to replace my JTech bulbs with a pure white bulb now also. do you know which LEDwholesaler bulbs from amazon will fit? (map lights and license plate lights)
Old 08-11-2014, 08:56 PM
tmfit's Avatar
Another great find! Got one on order myself! Thanks for the info
Quick Reply: Cargo LED -Huge Improvement!
