Fuses
Fuses
I have Starter System lit up on the dash, and a member said that's a fuse issue - missing fuse, with a TSB about it. Do any of you know where that fuse might be? The Owner's Manual lists them by numbers, but the fuse boxes don't have numbers. There is almost-invisible writing in the lid of the fuse box in the engine compartment, but it doesn't match up perfectly with what's in the car. It shows three horizontal rows and one vertical. That's not what's in the car.
There are also several Omron relays, #G8HL-H71.
Aliexpress.com : Buy G8HL H71 12VDC from Reliable omron cable suppliers on Cazenove electronics co., LTD | Alibaba Group
The fuses I ordered from Amazon won't be here for over two weeks, so I went into town and bought some. They didn't have much of a selection of the low profile mini fuses at Advance Auto. I got a pack of 25 10A for $11, and a mixed pack of 5 for $5.00.
There were two missing 7.5A fuses, one location marked DRL, but the DRL have always worked. I'll have to reset the error code with my OBD diagnostic tool. I don't think it resets itself. I'll do that later.
TWGE08
06-10-2009 07:54 PM
