Question on Subwoofers for new 2015 Honda Fit
Hey guys,
I was wondering if anyone knows if the 7" display audio infotainment system on the EX and EX-L trims includes a subwoofer or RCA audio out?
I was thinking about getting a Kenwood KSC-SW11 powered sub that should fit in the passenger seat well under the dash.
I have no experience installing speakers and it would be cool if there was as little manual wiring/splicing as possible.
Thanks for the help!!
Link to the sub:
Link to the sub:
Just buy a subwoofer amp with speaker level input (high level). Splice a wire from the L and R speaker wires to the input on the amp. Very few stock systems have pre outs.
Speaker level is better because it typically has more voltage than most pre outs, so more voltage means less noise. Most aftermarket pre outs are only 2-4 volts, some people will run a pre amp to achieve as high as 10 volts to bring the noise level down.
A power amp typically produces much more noise than a pre-amp line-level output. More voltage does not mean less noise. It may allow you to get less noise from your aftermarket amplifier, but that may not mean overall less noise. Power amps are typically noisier than line-level preamps.
No, they're all multi-position connectors. Audio outs are a couple pins per speaker (other than the tweeters which appear to be fed by a crossover somewhere) on a 24-position connector, video inputs are single pins on a different 24-position connector (each also has a ground for the entire assembly). That said, you could possibly wire an RCA jack onto the multi-position connector.
No additional video inputs besides the HDMI.
Plus the fact that we are talking about a subwoofer amp but typically any such noise variation would not perceivable to the people sitting up front.
So yes, in cases like this, using speaker level inputs is certainly just fine, many modern amps also go a step further internally using other methods to eliminate noise as well....assuming it's a good amp and not Pyramid or something.
Using speaker level inputs sucks because the signal is being crossed over according to the speaker it's going to. In the case of my 2015 Fit, the awful factory rear door speaker is probably cut off below 120hz. I tried hooking up a Bazooka to the rear speakers and it's useless. That same sub sounded fine in another car using line level inputs. Hopefully someone can poke around and figure out a way to get line level audio out of the head unit.
