Yakima Roof Rack Now Available
I just did a check on Yakima's website for a 2015 Fit and they now show a compatible roof rack system. The system uses Baseline Towers (This must be a replacement for Q-Towers), Base Clips 156 (B15-5) and 165 (B66-5), Round Bar SL-Adapters, and of course the round bars. Aerobars are likely available, too, I already own round bars so I didn't select them. This is partially good news as I don't need to buy an entirely new system. I do not know if there is a Q-Clip available for older systems.
You're probably just as well off. I contacted Yakima and there is no Q Clip for the GK Fit, it's only compatible with the Baseline Rack. The tower, clips, and adapters cost $325, but the bomber bars are still usable - an $89 savings off the $404 entire package. The one good thing I noticed is the Yakima Fit/Compatibility Check showed support for 165 lbs with this application. That is a pretty big difference compared to the ~105 lbs load limit of INNO and 132 lbs for Thule. I bought a set of Q99 clips for our 2013 Fit but I haven't had to use them yet. I won't be surprised if when I finally get around to buying a rack for my GK that it's Yakima despite how long it took for a solution with competitors products existed. I like that the their tool indicated 165 lbs. and everything else I own is Yakima.
The fit tool can be found here: Yakima Infolookup. I'm surprised that the Q Towers allow 124 lbs on the MY 2013 Sport and 109 lbs with the Baseline rack. As long as our Frontloaders and Big Stack work and our bikes and kayaks are within the load limit, that's all that matters.
You're probably just as well off. I contacted Yakima and there is no Q Clip for the GK Fit, it's only compatible with the Baseline Rack. The tower, clips, and adapters cost $325, but the bomber bars are still usable - an $89 savings off the $404 entire package. The one good thing I noticed is the Yakima Fit/Compatibility Check showed support for 165 lbs with this application. That is a pretty big difference compared to the ~105 lbs load limit of INNO and Thule.
Can you guys with roof racks give me an idea of what the MPG difference is with and without the rack, rack + bike/kayak/etc, and without the rack system at all in your personal use?
I'm going to get a rack no question, but I'm wondering if I want to throw down for a fancy hitch mounted system or a Thule/Yakima roof rack system.
Thanks!
Thanks!
I have the Thule rack and AeroBlade roof bars. Not even a whisper of sound from the rack and haven't seen any effect on my MPG.
For hauling my kayak I chose the Thule Hullavator, but don't keep it attached to the rack when I don't need it. It takes about two minutes to reinstall each one, and about 20 seconds to remove, so it's no big deal.
Also have Thule locks on the rack and the Hullavator.
Thanks!
Thanks!
I haven't. I have the Q Towers and clips for our '13th, which will be the default car when I need it, but haven't tried them yet, either. I still haven't decided if I want to stay with Yakima after how ridiculous support for the third gen Fits had been and being told to install a permanent rack.
I've been hauling my kayak on my Thule rack all summer and the roof looks as perfect as it did when I got the car in December.
Can't say the same for my front side fender, as I've accidentally bumped it when taking my boat off the roof - nothing serious, just a couple of light scratches. And then there was the log on the ground I didn't see when backing up...
Here's the Yakima rack with the Jetstream bars (aero bars) on my Fit.
I have two frontloaders on it now, but no pictures.
The bars don't make too much noise, but the bike racks (frontloader) does. And it has affected the MPG a little bit. I probably lose 2-3mpg with the bike racks on. I don't lose much maybe
Also, I thought the load capacity for the Thule system was around 165, not 132 or whatever.... I hope it is at least, cuz I did this over the weekend.
Can you recommend anything that hugs the roof more closely? I dont have a moonroof and would be willing to remove/modify my radio antenna. I want to do a full roof box. (made of PVC filled with expanding foam and painted black )
tmfit
191
07-22-2019 01:43 PM
da9r00d
05-02-2012 03:13 PM
bwb
50
10-16-2009 10:39 AM
