CVT Transmission doesn't vary on 2015 LX
Old 03-18-2017, 02:26 AM
BrotherBeijing's Avatar
Driving my daughter's 2015 LX CVT Fit and on the freeway today and the CVT stopped varying the gears. Now if I drive uphill I have to drive slow, 5MPH sometimes. The max I can drive is 55 MPH on a flat road. The engine light is ON. I wonder if it's just a blown fuse?
Old 03-18-2017, 08:21 AM
ab30494's Avatar
take it to orielly or auto zone, and see what the check engine light is on for.
Old 03-18-2017, 10:41 AM
wasserball's Avatar
Auto retailers diagnostic readers give only very general information. You need to take the car to someone who is familiar with your problem.
Old 03-18-2017, 03:02 PM
ezone's Avatar
Warranty? Dealership ASAP
Old 03-18-2017, 04:53 PM
Warranty expired. My daughter lives permanently in the US and keeps this car for family extended visits since there is so much to see in the United States.
It's as if the computer link between the engine and transmission has failed. The CVT is stuck in one position. The larger the incline you ttry to climb the slower the engine starts to buckle and vibrate. Not very impressive for Honda.
Old 03-18-2017, 05:01 PM
ezone's Avatar
Warranty expired.
How many miles? Powertrain is covered 5/60 for internal failures
What's the fault code?
Old 03-18-2017, 05:28 PM
To many miles
I haven't checked the fault code yet. Driving another car for now.
Old 03-20-2017, 12:15 PM
bargainguy's Avatar
While I'm not one to frequent dealerships if I don't have to - preferring independent shops and doing my own repairs if I can - I wonder if this is a software issue rather than a mechanical issue. For that reason, I'd probably pay a Honda dealer for a diagnosis. You can always specify diagnosis only and no repairs without your authorization.
Old 03-20-2017, 07:13 PM
wasserball's Avatar
I suspect it is a sensor issue. Software doesn't break or suddenly goes haywire.
Old 03-21-2017, 11:59 PM
Which sensor do you suspect?
Old 03-22-2017, 12:53 AM
ezone's Avatar
He was simply assessing a hardware fault instead of a software fault.
Figure out the fault code, then we can discuss facts instead of theory.
Old 03-22-2017, 10:26 AM
Do you have a diagram of the circuitry to the CVT?
Old 03-22-2017, 11:03 AM
dwtaylorpdx's Avatar
Recall status? there were a couple issues with 2015 CVT's IIRC...
Old 03-22-2017, 12:58 PM
ezone's Avatar
Don't you have fault codes from the car yet? It's been several days since you started this thread.
You can purchase a simple code reader for less than $20, or go to many auto parts stores where they will read codes for free in hopes you buy a laundry list of parts to load your parts cannon with. Get the actual code numbers, not the shopping list.
You can find wiring diagrams and almost all of the same service info a dealership has, at Honda Service Express: https://techinfo.honda.com/rjanisis/logon.asp
Note: No free rides.
Check your VIN for any needed recalls at
recalls.honda.com
(USA)
honda.ca/recalls
(Canada)
Old 03-22-2017, 08:14 PM
How many sensors are present? Which sensor do you think failed?
Old 03-22-2017, 09:11 PM
ezone's Avatar
A bunch.
How long are you going to drag this out?
Old 03-23-2017, 10:00 AM
Is there a schematic of the 2015 Fit wiring system online somewhere?
Old 03-23-2017, 10:19 AM
wasserball's Avatar
Yes, somewhere over the rainbow. What are you going to use it for? It's not going to solve your problem. I think you like a non functioning CVT, right? It fun to drive it that way, ie, one gearing.
Old 03-23-2017, 08:13 PM
Do you have a link to the 2015 Fit wiring schematics?
Old 03-23-2017, 09:25 PM
Fuelish's Avatar
Quick Reply: CVT Transmission doesn't vary on 2015 LX
