Oil change on the GK
Oil Change in 2015 Fit
Hey all,
I'm a little over 5K miles in my 2015 Fit and I'm wondering how often I really need to change my oil, and what the pros and cons are for using synthetic oil. I drive a lot if that matters.
Thanks!
Thanks!
I want to begin changing my own oil and this will be the first (car) and time I will attempt to do so.
Are there any video tutorials or instructions for how to do it on a 2015 Fit. (Apologies in advance if this is something I should already know but gotta start somewhere i guess)
Also what type of oil (amount), filter, anything else i would need?
Thank you to all.
Thank you to all.
Oh man... I think this thread is about to get ugly...
All I will say is that changing oil is really easy. You'll have no problems even if it's your first time. There are some pro-tips that can be found, but just look for a YouTube vid and you'll learn what you need to know.
I don't know the capacity, but it is definitely in the manual somewhere.
Type of filter is going to be a debate... the service adviser at the dealer said the OEM filters are best (obviously), but I looked at some cutaway videos of the Honda filters and they appear to be cheaply made. I think there are better options. I'm curious what answers you may get for this one.
I plan to use full synthetic but I'm not prepared to debate the pros and cons of each. I *think* that all 0w20 oils are at least semi-synthetic to achieve that low of a viscosity.
One tip I will give: used oil and filters can be disposed of for free at most auto parts sores.
Good luck!
Good luck!
You can buy 5 quart jugs of mobile 1 and a decent filter for like $45 PLUS you won't be up-sold on stupid services they try to convince you you need.
Really, youtube will teach you whatever you need to know.
OP: Just follow the maintenance minder for when to change your oil, or once a year if you don't drive enough to get the oil life down that fast. Any quality 0W20 is fine, they are all at least synthetic blend anyway.
5 qt Mobil 1 at Walmart = $25
Wix oil filter = $7
$32 + Tax
I'm going to guess it takes about 4 quarts if it's anything like the old L15, but definitely not over 5. Just add 3.5 quarts and start it and check the dipstick, add as needed if you're too lazy to check the manual. Filter is easily accessible and should be the same filter as every other Honda on the planet uses (they all use the same filter now).
Wix oil filter = $7
$32 + Tax
Mobil 1 Extended Life goes 15K miles. I recently watch a video on a Toyota Corolla valve cover replacement, and the engine looked super clean using that oil. To do your own oil changes, get the right tools, and elevate the vehicle using blocks of wood or low-profile ramps. I always start with the vehicle hot, and slightly loosen the oil filter first without breaking the seal...then I punch a small hole into the filter bottom allowing it to drain. Then fully remove the filter (oil above the check valve will still leak out...its normal) and remove the pan drain plug, allowing it to drain. Use a socket/ratchet set that is configured to loosen, so that you don't try to tighten the plug when trying to remove. Pre-fill the new filter with new oil, being careful not to over-fill and thus make a mess. Install filter making sure the new gasket has been oiled, and ensure the old gasket is not still on the mating surface. I turn the filter as tight as I can by hand, and then add about a quarter turn using my filter socket/ratchet. Re-install the drain plug (snug tight) and re-fill engine with new oil. I capture my old oil in a wide oil pan, and dump into 5 gal bucket that has a lid, or you can use the old 5 qt container. Keep a notebook on when the oil was changed, what size socket you need, filter model numbers for reference, oil capacity, etc. I also keep a small note card (I have 4 vehicles) with a mileage note as to when the next change is needed. I'm going about 8K miles using Walmart synthetic, but will use the Mobil 1 Extended on future changes.
I also have a special filter removal tool that essentially cuts into the sides of the filter as its twisted using a ratchet, but you can't use it for the re-install. The key points are: 1) make sure you can turn the filter from the start, 2) get it slightly loose before it and your hands get coated with oil, and 3) drain the oil out of the old filter. Been doing this for many years. I also pre-fill the new filter, rather than starting the vehicle with a dry filter.
The punch a hole in the filter method seems pretty sound. The only other idea I had seen was to put a large ziplock bag round the filter and then screw it off, so any oil that drains from the filter when the seal is broken is caught in the bag. Punching a whole seems easier.
As for filters (and I know there was a thread asking this question, but it quickly got off topic), what is your opinion on filter brands? I found a cutaway video on the OEM filters, and they seemed to be pretty cheap quality. I imagine there is a better option.
Only other comment: My Fit came from the Space Coast. I bought it at Southeastern Honda in Melbourne.
With extended length oil changes, the hold-up of the filter is a concern of mine.
Our Fit was purchased used (had like 15K miles or so) from the Melbourne area.
I’ve used the Wal-Mart SuperTech filters for quite some time, but unfortunately they are phasing them out and stocking Fram as almost an exclusive brand. However, according to a study I read several years ago, the Fram filters were inferior to most other brands. I’ve been using Purolator lately, but I can’t attest to the quality.
wait till your onboard maintenance remind on the car tell you to change it. i run mobil1 on my '09 and '12. i get my 5qt jugs from walmart for cheap and just keep the 1qt in the bottle top off (if required).
my 2 cents worth
Great filter comparison at gmtruckcentral They look at about every popular brand, and give you an actual comparison, from build quality to cost factor...
Also a very good air filter test on the same site.....I just finished about 3 hours
on the site....They are comparing chevy filters, but the filters are just a different size....was really surprised by the results.....
Ditto here. Can't beat Wally's for mobil 1!!!
Started with Fram decades ago but changed to Purolator back in '08 with my GD. Will be using their 14610 for the GK. As other have posted, look at the YouTube different filter cut-out comparisons. Can't go wrong for less than $4 for a quality filter.
So the Purolators are good filters? I was reading this thread and it seemed like the Purolators did a really great job catching solids in the oil.
I asked the service adviser what he recommends while they were "upgrading" my bumper, and naturally he said the Honda OEM filter is best, but I think there are better options and I'm glad to see that you agree.
P.S. Everyone wondering should check out the link above. The guy did some pretty extensive testing of a lot of different filters.
