Radio removal on a 2015 fit
so im looking for big and loud in my fit. i plan on throwing in my old 10 inch kickers and running a 1000watt amp on them along with a 650 watt 4 channel amp. ive noticed how tiny the batteries in the car are, am i going to need to go with a deep cycle battery to support that kind of amperage pull(had an optima yellow top in the old car, and actually ran 2 batteries in paralell for a while)? i know ive heard that capicators are very very last options after upgrading alternator wiring and ground wiring but im pretty sure i destroyed my old cars electrial system by using one so im a little afraid of them.
Happy shopping on the sound processor. There are many good ones available. Am sure you'll land the right one for your Fit. That said, am hoping you chose an Audison Bit One or Bit Ten. The sound in my LX Fit is not that loud but awesomely clear with a nice firm flat bass. Light years improvement from the OEM set-up.
Am running a 75wattx4 channel amp, 125watt powered sub. This set-up doesn't put a dent in the performance of the OEM battery. When I connect the Battery Tender every so often, it turns green (fully charged) within 20 minutes.
Don't forget to post once you start your project so others may learn!!!!
Nice job!
Is this the modified fit with the wide fenders I saw online? Your hood matches the custom color of it.
I just picked up my new fit yesterday and want to add a sub like I had in my 95 accord wagon but think the stock speakers sound fine except for the rear door speakers. Someone mentioned that they thought the OEM HU cut frequencies for those speakers and it sounds like it. Did you figure out if that's true? Are the stock door speakers the same front and rear?
wondering why didn't you cover more of your trunk and other areas withe dynamat? Over covering existing OEM sound deadening is over kill. How did you get the center dash out? I am starting to put in a SQ system in my fit as well. I notice our battery is soooo small, putting in a optima battery in there might be an issue. and do anybody know out alternator amp out put? 85 amp i guess?
Hmmm Im also wondering if I should upgrade my battery too but so far so good? Im running crazy power hungry amps 1350watt RMS and 900watt RMS with a 10 farad cap. No dimming while engine is running. I am still a little worried if these amp is going to ruin the stock battery in the long run. I don't want to be stuck somewhere.
I don't think he was looking to make the whole car quiet from road noise. To me it looks like he is just getting rid of any rattling.
Just pull and don't break it, lol. Its not easy but I got it done. Forgot to make a video and would rather not do it again : \ Yeah, it was that bad...
heres a tip that wasn't obvious from the pictures.
The ENTIRE piece comes up (part of the black dash-looking material attached to it too)
Don't try to pry it up between the silver/black, thats not where it comes apart.
Also, I closed the vents so I wouldnt push on them, but i pushed towards the windshield and UP with the palm of my hand on the top right side of the piece. This levered the piece upward (and detached the far right bottom plastic clip).
This gave me enough leverage to reach in there and pull the rest of the piece out.
I was stuck on this for about an hour.
Great thread with all the nice pics, which will help me out in the near future. I pulled a door speaker to see how my replacements would fit and think it is a no go. The door hole is way too small to fit the 6.5"'s that I bought, not to mention the whacky stock speaker attachment method.
Where did you guys, who changed speakers, get the adapter brackets shown in ROTTBOY's pictures?
Thanks
Thanks
Thanks
Thanks
#32
-Bump- Wondering this same thing. Now that its warmed up i want to start on my build. Ive decided im going to ditch the OEM interface and go with something that supports carplay since they are so slow to roll it out. Anyone dabbled with the getting the lane watch camera to work with an aftermarket unit?
Scosche SAHC634
Amazon.com : Scosche SAHC634 2006 -Up Honda Civic Door Speaker Adapter for 6 1/2-Inch Speakers : Vehicle Speaker Installation : Car Electronics
ROTTBOY confirmed via PM that those were the ones that fit the FIT.
#33
Here's another set of instructions if anyone is interested
http://www.metraonline.com/files/pro...7883HG_web.pdf
#34
The answer was obvious after looking through some of the pics.
Scosche SAHC634
Scosche SAHC634
you can also buy one that fit exactly like the stock one and also use the same one bolt like stock too plus this way there is no extra holes.
http://www.ebay.com/itm/121139880768?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
#35
6 5" 6 75" Car Stereo Door Speaker Install Mount Adapter Plates Select Honda | eBay
#37
I haven't really done any searching on here but what are people using for aftermarket headunit mounting?!? im going for a double DIN and have ordered this.
http://www.metraonline.com/part/95-7883HG
Thanks for the replies with the parts for the door adapters!
#38
#39
Massive kudos to Superfly for the pics! I can't thank you enough.
Got done installing a new head unit by following your tips.
If you're ever in Jakarta, beer's on me!
Only problem was locating the bottom screw. Which you said is visible "when removing the glove box" but I couldn't see mine...took ages to realize that your car is a left hand driver side!!! hahaha...so in my car, it's towards the driver's side
Anyways, thanks again!
#40
Thanks
Thanks
