Progress Rear Sway Bar
Part#: 62.1063
Thickness: 19mm
Finally got a chance to install my Progress rsb. Straight forward install, takes maybe 15-20m including jacking up both sides of the car. After lowering the car, be sure to retorque the bolts while the car is on the ground. Bar is built very well and hugs tight to the body. Do not have to worry about it ever scraping on the ground or getting caught on anything.
Impressions:
Noticeable difference going over bumps and taking turns. Nothing dramatic and you probably wouldn't notice the difference unless you were looking for it. Rear stays planted much better, though. For example, when going over bumps or unevenness in the road, you can feel the rear rebound quicker as the rsb is displacing the bumps and having both sides work together now. Likewise when taking consecutive or hard turns, you can feel the rear following around and being more compliant now. Feels much more stable and gives you a little confidence. Not enough for oversteer, so i wouldn't worry about that.
Negatives, the rsb transmits more road noise into the cabin. Hitting bumps and whatnot, you can hear the noise coming into the cabin from the rsb it seems like.
For the cheap price, i'd highly recommend getting this and installing yourself. You literally put bolts into existing holes then tighten it down with supplied nuts.
FedEx is dropping one off tomorrow for my '15 LX ....looking fwd to it
<edit> ....finally got around to installing it, straightforward and easy install. And I agree with your overall assessment, although I don't notice any additional road noise, at this point. Adds "oversteer" but not enough to really override the inherent fwd understeer, feels much more balanced in spirited driving...definitely worth it, to me ... dunno why a rsb isn't standard, doesn't affect ride comfort and is a lotta fun. If they spec'ed it for every Fit, wouldn't really add much at all to the cost of the car. Nice product....I put a Progress "stabilizer bar" on my '05 Corolla (replaced the 19mm factory bar with, mmmm, 25 mm, iirc....another easy install which definitely helped reduce understeer...my son drives it now for commuting to college)
Very impressed by the sway bar
I installed the progress bar last week and I am very impressed by the improvement in cornering. My son even noticed the difference at 25mph in the development when I pulled it side to side.
All these cars should come with these. Cheapest improvement you can do. I would make this modification first.
Shocks, springs, tires next week.
i believe torque specs are in the instruction manual. Cant remember but i swear i saw something ! Enjoy the RSB, im lovin mine errrday!
Progress Technology recommends that all hardware be torqued to 65 ft-lbs.
A copy of the installation instructions should be included with your purchase as well.
Look at first post, there's only one way it'll get mounted. You'll see when you're under the car
How'd you get the small bolt in front of the shocks as stated in the instructions. I had to go from underneath then had the nut on top. I haven't test drove it yet, waiting on a reply
How do you like it? I have the same rear anti-sway bar installed on my GK5 and I absolutely love it!
I'm sure I'll love it once I get it properly installed. I can't get the nuts screwed onto the bolts more than 2 turns. Not one, but all four! I left a message for Progress guys to call me. I do know they have an excellent customer service and support. I'm sure they'll call back tomorrow. So much for my test drive after dinner.
Got back from a trip and Progress came through!! In particular, Jeff from Progress sent the correct nuts that go with the bolts. I searched Ace Hardware, Home Depot, Lowes, and even Sears Auto but couldn't find the right size. Anyway, got and installed the RSB. There is a noticeable difference when going through corners and as I found out last night the Fit felt more stable in crosswinds. I didn't notice much difference in noise, but I did notice more stiffness hitting bumps. And this probably isn't because of the RSB, but I hit an all time high gas mileage or 44mpg highway since buying this car this past June.
