Wheel lug torque?
Old 02-07-2015, 10:40 PM
Great Evil's Avatar
Wheel lug torque?
Anyone know the torque specs for the wheel lugs?
Old 02-08-2015, 12:31 AM
DrewE's Avatar
It should be in the owner's manual—at least, it is for my 2012. (It was 80 ft-lbs if memory serves.)
Old 02-08-2015, 06:43 AM
cookiemech's Avatar
Owner's manual does say 80 ft-lb for installing the spare. 80 is a very common number for Hondas, so I'm guessing it applies for the standard wheels as well.
Old 02-09-2015, 01:42 PM
Great Evil's Avatar
Thank you. That's where I was confused, as the owners manual only shows the tightening torque for the spare at 80lb. I just assumed it would be the same for the regular wheels.
Old 02-09-2015, 02:48 PM
GeorgeL's Avatar
Since there is no torque wrench with the car the exact torque isn't terribly important. As long as the nuts are tight (and not overtightened) they should be fine. The stock wrench is made to allow sufficient tightness when used by a person of average strength.
If you are Hulk Hogan use caution, if you are Twiggy you might want to get a friend to tighten the nuts.
I prefer to use an aftermarket lug wrench shaped like a cross. It is less likely to damage the nuts but does require caution as it gives more leverage.
Old 02-09-2015, 03:59 PM
cookiemech's Avatar
GeorgeL, you must be in my age range (58) for you to use the Twiggy reference!
You're right, of course, about wheel nut torque. I use a torque wrench in my garage, because I enjoy the process, but if you just get it "nice and tight", it will be fine.
Of course, you have to have some feel for "nice and tight" . . .
(another George)
Old 02-09-2015, 06:08 PM
GeorgeL's Avatar
You just tighten it until it gets tight, then loose, then back up until it's tight again!
Old 02-09-2015, 06:28 PM
Wanderer.'s Avatar
I would assume if OP is asking the torque specs he has a torque wrench.
If one does not have a torque wrench and they work on their car at home, one should purchase said torque wrench so there is no guessing if anything is too tight or too loose.
Sometimes people are sausage fingered and ham fisted and they don't realize it, I've seen some engine blocks and heads get cracked that way lol
Old 02-09-2015, 07:16 PM
rodney's Avatar
lol... i have 4 torque wrenches...
Old 02-15-2015, 04:29 PM
Fitmo's Avatar
Who needs a torque wrench? Just tighten it until it strips then back off 1/4 turn.
Old 02-15-2015, 11:31 PM
Im going to guess the wheel studs are M12x1.5, so the proper torque for an alloy wheel would be 70-80Ft/Lbs.
Old 02-18-2015, 12:23 AM
555sexydrive's Avatar
I always tighten to 75ft-lbs, tighten by hand and then bring in the torque wrench for the final top off.
Old 09-15-2015, 12:49 AM
phenoyz's Avatar
I assume it also apply to the 2011 GE...
also anyone recommend a good torque wrench?
relpacement lug nut :
Amazon.com: McGard 65457BK Chrome/Black SplineDrive Wheel Installation Kit (M12 x 1.5 Thread Size) - For 4 Lug Wheels: Automotive Amazon.com: McGard 65457BK Chrome/Black SplineDrive Wheel Installation Kit (M12 x 1.5 Thread Size) - For 4 Lug Wheels: Automotive
torque wrench :
Amazon.com: GearWrench 85074 1/2" Flex Head Electronic Torque Wrench with Angle 25-250 in/lbs: Automotive Amazon.com: GearWrench 85074 1/2" Flex Head Electronic Torque Wrench with Angle 25-250 in/lbs: Automotive
FitRocket
05-08-2013 05:46 PM
annunC8
02-14-2013 09:47 AM
Crawly
02-25-2008 10:36 AM
rlhannan
12-31-2007 02:15 PM
saralee
10-29-2007 03:13 PM
Quick Reply: Wheel lug torque?
