Quote:
Originally Posted by Firebat666
ive heard to tell if your clutch is slipping, shift into 4th or 5th as normal, then slam on the gas, if your revs. go up without a big speed increase, your clutch is slipping, can any one confirm this?
yes, its the same if you shift 1-2 fast, but when that starts happening you need to get it changed asap to avoid any problems of getting stuck somewhere, it will get to the point where you just dont move
