nEED help installing Megan coilovers
Old Aug 26, 2008 | 04:30 PM
FELIXY69's Avatar
hey guys
after all the trouble i've been having with T1r...i got a set of megan
but the box came, and does't come with any top hats or bushings which megan said they would have all the bushing and all the top hats ready when i order it.
without my Old set of shocks here to see what i need to put on the megan from the oem shocks as an example
can anyone tell me what i need to take off from the OEM shocks ? and install my megan coilover kit
thanks
Old Aug 26, 2008 | 07:12 PM
the megan came with the top spring holder, correct? you would
place the metal "hat" from the stock strut along with the mounts
on top of that holder.
just make sure you remove the boot holder (just pry it off).
should work as long as the top spring holder was included in your kit
or the top of the spring matches the diameter of the stock hat.
Old Aug 27, 2008 | 04:58 AM
FELIXY69's Avatar
ekk...ay pic as reference ?
for the front, are you talking about #2,9,11,8, 13,14,18,17, 7 ?
as for REAR # 6, 3, 8 ?
Old Aug 27, 2008 | 06:06 PM
you'll need 9, 11, 8, 13, 14,18,17 (unless the megans come with one).
Old Aug 27, 2008 | 06:20 PM
c_mack9's Avatar
yes.........
Old Aug 27, 2008 | 07:17 PM
Spooling's Avatar
I heard that Megan coils are really not up to the standards.. is it true?
Old Aug 27, 2008 | 10:52 PM
QuickGD3's Avatar
2 not needed for coilvers??
Why would you need item number 2? Doesn't the megan coilover/skunk2 pro c coilover come with their own spring top hat?
Old Aug 27, 2008 | 11:17 PM
that's only the plastic bracket so if the top of the coil diameter and
the cross-section diameter of the coil itself is the same as stock,
they can use it... just like running lowering springs with stock top
hats, i guess.
Old Aug 27, 2008 | 11:47 PM
QuickGD3's Avatar
hats, i guess.
i c...
xcsp800
Mar 4, 2011 03:59 PM
bigg_kidd
May 9, 2010 02:49 PM
FELIXY69
Oct 26, 2009 09:49 PM
nikkarocky
41
Jul 31, 2009 07:46 PM
Coffey
Aug 10, 2007 02:20 PM
