View Single Post
  #22 (permalink)
Old 09-02-2008, 01:09 PM
Tofuman's Avatar
Tofuman Tofuman is offline
Tofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to liveTofuman relies on Rep Points to live
Quote:
Originally Posted by chinkyy View Post
so the d specs are not height adjustable but they have the dampening ability?
the d-specs are just the strut/shock only. not full coilovers. the height of the car will not change by using the d-specs. you can put on different springs if you want to be lower, but if you want adjustable height, the only way to do that is with full coilovers or coilover springs like ground controls.
__________________
2009 MPG 2008 MPG
