Sponsored by:
Sponsored by: CARiD
To K-swap or not?
Old Sep 4, 2008 | 10:24 PM
Chitownfit's Avatar
To K-swap or not?
I just wanted to get some feed back about how my fellow Fitfreaker's feel about
the K-swap. Good idea or bad let me know.
Old Sep 4, 2008 | 11:04 PM
K20A3Fit's Avatar
neither good or bad, its an amazing idea. Go for it.
Old Sep 4, 2008 | 11:18 PM
explosivpotato's Avatar
I think it's mostly for "extreme value." Yeah, its faster than a fat kid on a twinkie, but its really complex and hella expensive. Personally I chose boost instead, less in-depth (and I've wanted a turbo car since I was 4 lol). Up to you, really. You'd be one of the handful who have pulled it off!
Old Sep 4, 2008 | 11:21 PM
zRollerskate's Avatar
Nuff Said'
Old Sep 4, 2008 | 11:35 PM
drzenitram's Avatar
the thing about swapping to the K engines is that you're driving with a brand new honda engine. you're not forcing more power into it than it was made to have so you have 100% honda reliability and twice the power of a normal fit.
unless you're doing autox, I say DO IT!
Old Sep 5, 2008 | 12:07 AM
eldaino's Avatar
do it for kicks and to get the oohs and aaahs, especially from people on this site....
but the most ecnomical way to power? no. not by a long shot.
and if you do f.i. right, it can be almost as reliable.
its not like you are boosting an old hyundai excel or something.
and it throws off the fits balance a lot more than k swaps into civics and integras does.
Old Sep 5, 2008 | 02:15 PM
Injundon's Avatar
okay here's my take on the matter.
Swap in a K24 from an accord/CR-V. motor with RSX 5 speed transmission is around $1500. (instead of $5g's for a K20) then add the supercharger kit for it, and you spent the same as a K20 swap with around 250Whp and balls of torque.
Old Sep 5, 2008 | 02:17 PM
Previc93's Avatar
I would do the swap if i had the money. im thinking about boosting my car right now though cause i dont have that kind of money. but def would recommend the k swap.
Old Sep 5, 2008 | 02:25 PM
Fitcapo's Avatar
I would love to swap but I drive a auto so that is a no go for me
Old Sep 6, 2008 | 04:44 PM
Chitownfit's Avatar
What numbers are people getting one forced induction on the 1.5L versus a stock K? Also how much heavier is the engine really?
Old Sep 6, 2008 | 05:55 PM
Fa1's Avatar
Fa1
The current turbo kits out with upped psi gives around the same whp as a stock k20a2 but quite a bit more torque.
I've heard a K weighs a little over a 100lbs over a stock L15.
Old Sep 6, 2008 | 06:06 PM
eldaino's Avatar
you could always do an accord k24 or a rsx base engine.
i considered this for like five minutes, but the torque of forced induction would be on par if not better, and cheaper.
the k engines are not the heaviest things in the world, but they weight a good deal more.
i think in actuality its only like 40-50lbs....
but then again, people here make a big deal out of how heavy the stock wheels are so i guess 40-50lbs extra would be pretty bad, even despite the power offset.
i would mostly be worried about fitment. you could go the accord route and spend less, but shoving it in there is where you may encounter problems.
I will say this though. I have a friend of mine who has an 02 rsx base 5spd mani. his base k20 was shot because he drove it all dumb and crap, so he found a honda dealer that would give him a deal on an accord k24. he got it for like 900 bucks with low miles. he swapped it out, got kpro and that thing is a torque monster.
i personally think he's lowsy at shifting and he is making about 160 whp with no i/h/e, just the engine and tune, and with three of us in the car, he ran a low 8 second 0-60, for very cheap. not to bad imo, and minus 200lbs on a fit would make this even sweeter. but the balance would be all off.
Old Sep 6, 2008 | 06:13 PM
Fa1's Avatar
Fa1
If you consider going k24 I'd take the older k24a1 from the crv or the k24a2 from the tsx. iirc if you plan to change to a k20a2 or z3 head there will be piston to valve contact with the a4 blocks.
Old Sep 6, 2008 | 08:12 PM
Injundon's Avatar
with the $3500 you save doing a K24A1 swap instead of K20A2 (RSX-S) it leaves you enough money leftover to supercharge the K24 and put you miles ahead of the K20A2. And swap over boosting the L15 IMO is the better route even though it's heavier it's near stock HP so stock relibility. thicker axles, and easier access to a beefy clutch.
Old Sep 6, 2008 | 08:41 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
if you can afford it, get the swap
Old Sep 6, 2008 | 10:58 PM
eldaino's Avatar
stock reliability only if its in the original car that engine was intended for.
k series into anything other than a car already that was equipped with one is no b series swap job (and even those have issues.)
if skunk 2 can beat on thier l15 14lbs boosted fit, i'm pretty sure less psi f.i. applications will be a ok.
and no loss of balance either.
Old Sep 6, 2008 | 11:13 PM
Chitownfit's Avatar
Great info people, just the stuff I needed. I think I'll head in the
K-swap direction.
Anyone in the Chicago-land area that has a
garage that I could rent?
Oh, I'd hate to change the subject but has anyone heard how the
engine holds up to NOS?
Old Sep 6, 2008 | 11:40 PM
Injundon's Avatar
K-swap direction.
Pouring energy drinks into your engine is VERY bad!!!!
a K24A1 can easily handle a 75 shot of NITROUS OXIDE...
stop saying NOS.. it's a brand name not an actual product.
Old Sep 7, 2008 | 02:47 AM
Chitownfit's Avatar
LOL, ROFL.....dick.
NOS = Nitrous Oxide Systems.
A soft drink in to an engine.....stop it your killing me!!!
Old Sep 7, 2008 | 03:40 AM
drzenitram's Avatar
I wonder how much the labor would be for the $1500 motor w/ecu/transmission/etc?
