View Single Post
  #17 (permalink)
Old 09-11-2008, 02:44 AM
YeeFit's Avatar
YeeFit YeeFit is offline
YeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to live
Quote:
Originally Posted by Sugarphreak View Post
They did say the map is adjusted to suit a higher elevation. It should be easy to trim fuel from the map they created if it is still rich.
So what is the plan then? You want to check out the A/F back at the Mustang shop before doing anything?
EDIT: on a side note it looks like no more upgrades for the E-manage software... Greddy just went bankrupt
Just a quick touch on the emanage harness. You probably can't just unplug the harness. Atleast from my experience with the turbo install I had to actually cut and bypass a few wires from the ecu to the emanage. If you just unplug it your injectors may not shoot any juice!
Yours may be different tho.
I'm sure Greddy will get bought out.. when did they go bankrupt? It doesn't really make much sense as they are a pretty huge company and have provided high quality aftermarket parts for years. Greddy going under is like saying HKS is going under..
If you can't find you emanage disc let me know. I have mine.
