This is discussed in the US manual, pages 83-87 (at least in the .pdf version downloaded from the web).
The auto-unlock procedure for when you turn the ignition OFF is:
- Car off, transmission in P (auto only of course)
- Put the ignition in the ON position (do not start vehicle)
- Push and hold the brake pedal down and shift out of P (auto only)
- Push and hold rear of master lock button until you hear the 2nd click (5 seconds)
- Release master lock buttonand within 5 seconds turn ignition to Accessory setting
- Shift back into P (auto only) and release brake
- Turn ignition OFF
