You ICE GURUs... I need some wiring help
Old Sep 12, 2008 | 10:55 PM
JDMchris.com's Avatar
I run THIS
Ok. So im wiring up my headunit right now. I have 2 harness coming out of my headunit. I matched up all the colors to the Scosche harness... but now I have a free Blue wire(antenna control), and a blue/white wire(system remote control)
Where do these blue wires go? there are female connectors on each of them.
Old Sep 13, 2008 | 12:41 AM
I run THIS
Ok so I wired up the headunit harness to my scosche kit harness... on the headunit harness I have the Blue wire(antenna control), purple (reverse gear signal) which goes to the rear taillight, pink(speed signal input), black(ground) which is obvious, and the blue/white(system remote control)
On the scosche harness I have black(ground), pink(says TEL MUTE), black/white(doesnt say anything), brown(doesnt say anything), orange/black(dimmer ground), green/white(doesnt say anything).
Do i hook up speed signal input to the pink on the scosche? or does that need to be connected to the ECU? The scosche doesnt have any blue wires so where would those go? Do anything go connected to the unused wires on my scosche harness? Please help as I want to install this asap... Just want to get most everything done before it goes in! TIA!
Old Sep 13, 2008 | 01:00 AM
Rod2Rice's Avatar
Well the blue antenna control is probably for a power antenna, so hopefully you got the antenna adapter harness, otherwise you wont be able to hook the antenna up. If you do have that harness, thats where the blue wire from the scosche kit goes.
Not sure what the speed signal wire is, so can't help you there.
I dont recall my scosche kit having so many wires on it! Hope I helped at least a little.
Old Sep 14, 2008 | 07:44 PM
gimme's Avatar
Master FitFreaker
i'm in the same boat...all matching wires conected and i still have extras. weak!
Old Sep 14, 2008 | 09:14 PM
Injundon's Avatar
tghe blue/white is an amplifier turn on wire.. no amp, no use wire..
the solid blue if for the antenna amplifier all new hondas have. Most people have been getting beter luck not hooking this wire to the antenna adapter. so up to you if you want to use it or not. If they are not in use, please tape the ends up!!!!
Old Sep 15, 2008 | 11:51 AM
mrwilli1's Avatar
I would recommend you connect the blue wire to your antenna adapter. If you don't, you run the risk of lousy radio reception.
Old Sep 15, 2008 | 12:03 PM
I run THIS
i was missing the antenna adapter... this is why i was freaking out.. I got one and installed this yesterday and it all went flawless!
Old Sep 15, 2008 | 12:07 PM
gimme's Avatar
Master FitFreaker
damnit! so chris, did you do a video bypass? or did you do it the legit way?
Old Sep 15, 2008 | 12:11 PM
Injundon's Avatar
Chris bought a Pioneer, depending which model you hav to move a Pin on the RCA plug also to do a bypass. since the navigation will cut off at any speed over 3mph and tll you handbrake wire is impropperly connected
Old Sep 15, 2008 | 12:12 PM
I run THIS
Yup! Its real easy tho... Move that 1 pin (mute wire) and ground it along with the ebrake wire.
Old Sep 15, 2008 | 12:25 PM
Injundon's Avatar
. yup.
Old Sep 15, 2008 | 03:00 PM
Fa1's Avatar
Fa1
So where's the diy?
Old Sep 15, 2008 | 10:07 PM
gimme's Avatar
Master FitFreaker
dude, chris.......how many wires did you have left over on the scosche supplied harness?
Old Sep 15, 2008 | 10:27 PM
I run THIS
4 i think...
Old Sep 15, 2008 | 11:26 PM
gimme's Avatar
Master FitFreaker
oh okay, i am along the same lines. *whew*
Old Dec 26, 2008 | 06:16 PM
heymikesays's Avatar
alright, sorry to bring up an old thread. but im stuck on 1 last thing (i'm sure its easy but this is my first time installing a stereo) and I need to call upon your guys' powers. I'm down to 5 wires (I noticed the majority of you came down to 4), the 5th one is the reverse which I have no idea where to connect to? everything else operates, just don't know what to do w/that pink wire. thanks for any input/help
Old Dec 26, 2008 | 07:18 PM
I run THIS
The pink wire is the Vehicle speed sensor wire. The reverse wire you can run to your rear taillight, or find the wire near the Fuse box area. It is a green/black wire if I remember correctly.
Old Dec 26, 2008 | 08:35 PM
I saw on a previous post to locate the reverse light in the drivers side fuse box location but which harness has the green/black wire? I look in that area and I feel like I'm about to chop up stuff on a hunch.
Everything works already, the navi (did the speed sensor wire already), dvd (w/bypass thanks to kelsodeez), am/fm(w/reception), and cd, so I'm assuming the reverse wire is for the navi when the car goes in reverse? Do you think I would harm the navi if I just left the reverse wire off? It seems to pinpoint where I am regardless when I went to work and back today. Thanks
Old Dec 26, 2008 | 08:48 PM
I run THIS
If you look at the fuse diagram you will find the reverse light fuse. You can either connect it there or look to the bunch of wires near that for the wire itself.
Old Dec 26, 2008 | 11:16 PM
Rod2Rice's Avatar
Cant see why you'd need a reverse hookup for Nav to work. More than likely that is for a backup camera, providing the headunit supports one.
