FS: LED products
Old Oct 5, 2008 | 12:27 PM
Fit of RAGE's Avatar
FS: LED products
Hey everyone, I was just going through some of my LED stock and want to clearance some out. Here is what i've got:
6mm (wide) LED strips:
- FULLY marine grade water proofed out of the box
- coated with a thin layer of silicone resin
- Comes in 1/2 meter strips
- 12 volt power supplied
- comes with easy connector ends with each strip
- comes with 3M tape on back of all strips
- White, Warm white, Red, Blue, Yellow (warm white is like an incandescent bulb)
12mm (wide) LED strips :
- coated in a soft clear silicone resin
- Each strip comes with 3M tape on back
- White, Warm white, Red Blue
All strips are flexible horizontally. As you can see from the pics, you can even make a full circle with them. They take only 9 volts to light up, dim, and 12 volts to be at 100% brightness.
LED Modules:
- coated in a soft silicone resin
- roughly 1.5 x 1.5 x 0.5 inch (L x W x H)
- White, Red, Blue, Yellow
Here are some pics of them installed on my car.
Door Sills:
You'll need 3-4
Engine bay:
Trunk:
You'll need 2 strips
Headlights as R8 Style LED's:
Glove box:
You'll need one strip
http://www.youtube.com/watch?v=mYwFDVLfI8o
LED Modules as puddle lights:
WILLING TO SHIP ANYWHERE!!
Retail pricing:
6mm: $28/each
12mm: $35/each
Modules: $15/each
Selling for:
6mm: $22/each (my cost is $18)
12mm: $28/each (my cost is $26)
Modules: $12/each (my cost is $10)
If you are interested in having LED door sills, i can pre-wire everything for you and all you'll have to do is hook them up. Obviously the costs will go up because of the wiring that has to be done.
For us Metro-Vancouver-ites, installs will also be available.
Old Oct 5, 2008 | 01:49 PM
updated with prices!!
Old Oct 7, 2008 | 09:04 AM
updated with some better pics
Old Oct 13, 2008 | 10:58 AM
LED's going quick!! If you want some, NOW IS THE TIME!!
Old Oct 17, 2008 | 06:32 PM
Innie82's Avatar
Is there a difference between the brightness of the 6mm vs. the 12mm? Also, my car usually runs at around 13.8-14.2 volts, is this going to be a problem? and how do I pay your? thanks!
Old Oct 17, 2008 | 08:56 PM
There are 45 LED's in the 12mm and 24 LED's in the 6mm. Voltage is no problem. The LED's light at 9 volts (dim) and get REALLY bright at 12 volts. My paypal addy is:
AMGCLS68@gmail.com
Old Oct 17, 2008 | 10:56 PM
Innie82's Avatar
How many of the 12 mm strips do you have in blue?
Old Oct 18, 2008 | 02:19 AM
I've PM-ed you
Old Oct 21, 2008 | 02:32 PM
vshiva's Avatar
if i want to put the LED in the headlight, what size should i go? 12mm?
Old Oct 21, 2008 | 02:47 PM
JamesBizzle's Avatar
can i see how you rigged up the trunk lights? I may be interested.
THanks!
Old Oct 21, 2008 | 10:14 PM
6mm it's, easier to hid and wiring up.
THanks!
All i did was splice it into the trunk light. super easier
Old Oct 22, 2008 | 10:04 AM
ok, what I ment was where'd you place them exactly? I don't have a cargo cover, so I would like to see where you "hid" them exactly.
Thanks!
Old Oct 22, 2008 | 10:04 PM
Thanks!
Oh sorry, I've actually got them taped to the underside of the cargo cover. I"l grab pics of you when i get a chance
Old Oct 23, 2008 | 05:47 AM
thanks man.
Old Oct 23, 2008 | 08:53 AM
Keep the orders coming!!
Old Oct 25, 2008 | 02:49 PM
bumpity bump
Old Nov 24, 2008 | 05:12 AM
fitster's Avatar
the module lights?
are they 12 bux for each square?
Old Nov 24, 2008 | 12:41 PM
Originally Posted by fitster
the module lights?
you've been PM-ed
Old Dec 8, 2008 | 11:47 PM
bump bump bump
Old Dec 19, 2008 | 08:57 AM
Christmas bump
