View Single Post
  #8 (permalink)
Old 10-05-2008, 01:39 PM
kylerwho's Avatar
kylerwho kylerwho is offline
spoon fed
kylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to live
Send a message via Yahoo to kylerwho
Quote:
Originally Posted by underdog View Post
NOOOoo! that increases the piston to head clearance which reduces quench which could lead to detonation alot easier than just leaving it alone and spend more money on a professional tuner. there are several people out there that run high compression + boost with great results. look at all the boosted type R guys. they make the same hp as gsr's with typically 3-5 less psi and have a fatter power band.
its not always about lowering static compression. its about lowering dynamic compression! ie. cam timing, ignition timing, reducing backpressure(too small exhaust, turbine, ect....)free'er flowing systems will need less ignition timing to make the same power, thus reducing the chance of detonation but usually comes at a price. a little less boost response. however there are ways around that as well....twin scroll!!!
I will give you that lower compression gives you a buffer for mistakes. but the only way to do it right is custom pistons, or find a piston that works from another boosted engine with 73mm pistons 4 valves per cyl with same valve arangement. good luck.
you missed my winking face. that was a huge joke. Seems like a logical answer but it has some real bad effects.
__________________
high roller #7
Quote:
Originally Posted by dewthedew View Post
Yeah, I was thinking about you when i made that post. You're insane and I say go for it! you'll have the most badass fit ever.
