Alloy Wheel Care
Old Oct 12, 2008 | 06:49 AM
NEK FIT's Avatar
Alloy Wheel Care
Hi Fellow Fitfreaks,
I bought a Sport last spring and am getting ready to take off the wheels/tires and put on snows (already mounted on their own wheels). I was wondering about the best way to maintain alloy wheels. I've read in some places that the wheels have a clear coat finish, and that I should just wax them. So... Should I wax the wheels that my snow tires are mounted on (got them from Tire Rack) before putting them on the car, and should I clean and then wax my Honda wheels before putting them away for the winter? I'd appreciate any advice.
Old Oct 12, 2008 | 07:16 AM
HONDAMATIC's Avatar
take care of them like how you take care of your paint
Old Oct 12, 2008 | 01:07 PM
Adidas's Avatar
be carefull with them other wise they will damage very easily which makes u to spend huge amt
Old Oct 12, 2008 | 01:23 PM
feddup's Avatar
clear coated
The sport alloy wheels are clear coated like your car paint. When I rotate my tires before an oil change (5K) I diligently use wheel cleaner to clean of the brake dust and reapply my polymer coating as part of regular maintenance. Treat them as you would your other clear coated paint surfaces. If cleaning the backsides of the wheel is too much trouble then I can respect that as it's quite a pain in the A&s!
Old Oct 13, 2008 | 12:53 AM
dbarefield's Avatar
Yeah the other follow-up posts were also correct, but check out this article for some other tips on caring for your wheels.
Old Oct 14, 2008 | 07:21 AM
NEK FIT's Avatar
Do you use a particular brand of wheel cleaner and polymer coating?
I was also wondering if I really need to reapply the polymer coating if I'm diligent about waxing the wheels?
Old Oct 14, 2008 | 07:22 AM
NEK FIT's Avatar
Thanks for the link to the article. I found it helpful.
Old Oct 14, 2008 | 07:38 AM
feddup's Avatar
I use P21S wheel cleaner and wolfgang paint sealant 3.0 both of which can be ordered from autogeek.com . These are by no means the only products that will work. From the research I've done the best paint sealant is Zaino but I've not yet bitten the bullet and placed what may be $200 Zaino order. I doubt you have to be so anal about coating the wheels but I figure, while I've got them off why not. It does make the tire rotation day a pain in the ass but brake dust doesn't build up and it keeps them looking nice. The front of the wheels I treat exactly the same as the rest of the car.
Old Oct 14, 2008 | 07:47 AM
NEK FIT's Avatar
Thanks for your input on this. I've also read that a light coating of lubricant on the back of the wheel, before installation, will help to fight corrosion.
I think I'll just try a couple of coats of wax. Right now the wheels look pristine from the outside (and of course the ones I got from Tire Rack haven't even been on the car yet), so maybe religiously waxing and cleaning will be sufficient.
Do you rotate your wheels yourself, or do you have a garage do it? I'm thinking about doing it myself, or at least specifying that the mechanic use a torque wrench rather than an air gun to put the nuts on. Seems to me that an air gun would have a greater chance of damaging the finish on the nuts. Any thoughts?
Old Oct 14, 2008 | 07:57 AM
feddup's Avatar
black friday
I got my fit on November 2 07 and decided to buy a torque wrench so I could rotate my tires properly. I actually got up on black Friday at 3 AM because Sears had an $80 1/2 in drive torque wrench on sale for $40. My Honda dealership only charges $29 for an oil change but wants $50 for tire rotation. Go figure! I even came back a week later to re torque them. It's kind of a pain but I'm trying to be impeccable with the fit.
Old Oct 14, 2008 | 08:30 AM
NEK FIT's Avatar
I got my fit on November 2 07 and decided to buy a torque wrench so I could rotate my tires properly. I actually got up on black Friday at 3 AM because Sears had an $80 1/2 in drive torque wrench on sale for $40. My Honda dealership only charges $29 for an oil change but wants $50 for tire rotation. Go figure! I even come bach a week later to re torque them. It's kind of a pain but I'm trying to be impeccable with the fit.
Sounds like a good strategy. I'll look into getting a torque wrench. Do you use a floor jack, or the one that comes with the Fit?
Old Oct 14, 2008 | 08:34 AM
NEK FIT's Avatar
Hey, you're getting good mileage. I too use mild hypermiling to try to boost my mpg. So far I'm getting between 40 and 41 mpg on a stock '08 MR Sport manual, with most of those miles driven on trips. My best tankful was 43.9.
Old Oct 14, 2008 | 08:42 AM
feddup's Avatar
38.x
I can't get over 38.X! it makes me mad but I do mostly city driving. My BBP paint dictates that I'm not going to draft. I don't want my paint all ate up with chips.
Old Oct 14, 2008 | 12:44 PM
feddup's Avatar
sears
I hate to sound like a Sears fanatic as the brand has suffered over the years but I use 2.5 ton Craftsman floor jack. I got it with two nice jack stands for $30. The fits scissor jack will work and I encourage people to get used to it's operation before it's actually needed. I've changed flats on the interstate at night several times and it's not the time to be learning about your tools.
Old Oct 14, 2008 | 12:59 PM
to the OP.
as long as you use polymer based sealant you are okay on the wheels.
carnauba waxes dont last very long in high heat.
I use Prima Hydro after every wash to wax my wheels. Just spray,
and wipe down using a soft paper towel. you can get Hydro here:
www.detailersparadise.com
Hydro lasts over 4wks, so on my car's paint, i use Hydro every other
wash. you can Hydro plastics to dress it, over glass, etc. does not
whiten or smear.
hope it helps.
Old Oct 14, 2008 | 01:25 PM
feddup's Avatar
MF towels
Originally Posted by kenchan
This is where I got all my microfiber towels and their merchandise is stellar. They're pricey everyday but have excellent sales if you watch for them. Their "monster fluffies" feel like what a bathrobe at a five star hotel should feel like!
Old Oct 14, 2008 | 01:33 PM
yah, DP's a great store!
Old Oct 14, 2008 | 07:23 PM
NEK FIT's Avatar
Hey kenchan and feddup, thanks for all of the advice.
Old Oct 14, 2008 | 08:36 PM
davela72's Avatar
+1 for Hydro!
Old Oct 14, 2008 | 10:33 PM
feddup's Avatar
links
You can get better DETAILING advice from (can you guess?) detailers!
good site but only recommends products they sell which means they lack objectivity. Stii has some good info!
Autopia.org - The Car Detailing & Appearance Authority for All Car Enthusiasts.
DetailersClub.com
Autogeekonline Car Detailing Forum - Powered by vBulletin
for the ultimate polymer coating which I can't afford right now.
Zaino Store
You can research detailing till the end of time and they'll argue every bit as vehemently as fitfreaks. As always get your brain turned on (be skeptical!) don't listen to extremists!
Ric01
Jul 13, 2011 11:45 PM
jnesselroad
Mar 12, 2011 11:28 AM
Vash
16
Apr 23, 2010 03:50 PM
phil@detailersdomain
Mar 19, 2009 08:20 AM
jenhonski
Oct 11, 2008 10:50 PM
