rear disk brakes?
Old May 16, 2006 | 02:48 AM
siownschu's Avatar
rear disk brakes?
can it be done? i'm wondering if the Civic rear disk brakes from the EK model will match with the N. US spec Fits? they are 4x100 lug pattern also
Old May 16, 2006 | 08:17 AM
Bukwheat's Avatar
If Honda can put Brembos on their Fit concept...anything can be done as long as you're willing to spend the cash.
But seriously, one of the Asia members has done the rear disc conversion. Just browse through these threads and you'll find it.
Old May 16, 2006 | 05:23 PM
kentris's Avatar
Definetly can be done. No doubt about it.
UK Jazz ALL come standard with rear brake discs.
Old May 16, 2006 | 06:12 PM
dmun505's Avatar
well is it true that u can put the front discs to the rear?
Old May 16, 2006 | 11:00 PM
07Fit00S2K's Avatar
I would like to change out the rear drums to disc brakes too. I saw a pic in another thread of a Fit with aftermarket 5 spoke wheels. Those rear drums looked aweful behind the nice wheels. I would either go with a mesh design wheel to hide the drums or get a rear brake kit.
Old May 16, 2006 | 11:04 PM
aziatiklover's Avatar
Master FitFreaker
honda fit lug pattern is 4x114
Old May 16, 2006 | 11:11 PM
Illusive's Avatar
I thought the fit lug pattern was 4x100
Old May 16, 2006 | 11:17 PM
Master FitFreaker
iono man but most hondas' r 4x114
Old May 16, 2006 | 11:49 PM
JDMchris.com's Avatar
I run THIS
the fit are 4x100 as well as 88-04 civics. the only hondas that used the 4x114.3 was the accord and i think the early preludes
EDIT: forgot to add the JDM 96 spec ITR 4 lug
Old May 16, 2006 | 11:52 PM
Master FitFreaker
oh k thanks for the infos bro
Old May 17, 2006 | 02:37 PM
siownschu's Avatar
so can we take the rear disk brakes from a civic for example and put it onto the fit?
Old May 19, 2006 | 03:25 AM
Bukwheat's Avatar
Not sure....but you could try it and let us know!
I'm sure you'll be able to get the rear disc brakes off an EX at the local junk yard for cheap. Then, since you're lucky enough to be in Cali, go to any well known shop and they should be able to do it. If you don't know of any, go to AEM or 5Axis and they SHOULD be able to give you recommendations...or do the job themselves! lol
Old May 19, 2006 | 03:31 AM
aallbbeerrtttttt's Avatar
no you cannot, the whole rear end is completely different...
Old May 19, 2006 | 03:58 AM
Bukwheat's Avatar
That sucks. Well...you can always check with AJ-Racing or PolePositionProducts to see if they can get you the JDM ones....and if they fit.
Old May 21, 2006 | 01:08 PM
p11wrg's Avatar
We hae been looking into the Jazz/Fit set up. The discs on the Fit whether front or rear are no the same as any other Honda model When you look at discs you have these factors:
Diameter
Thickness
Offset
Vented or Solid
Centre Bore (should be the same on all Honda)
PCD
With the above variables, nothing in the current Honda line up is shared with the Fit.
Therefore for our 280mm Front disc conversion, will be using a casting which was originally designed for another car, but specs are near identical to the Fit but being 280mm instead of 242mm.....
Al.
Old May 22, 2006 | 01:34 AM
Paulo107's Avatar
i will miss the all wheels discs
Old May 22, 2006 | 02:09 AM
Master FitFreaker
me too I guess I will do teh conversion one day to be complete
Old May 22, 2006 | 05:07 AM
p11wrg's Avatar
i do not know about USA model, but for Europe and Japan, the front discs are either 230 or 240mm stock. 230mm is for cars with rear drums, and 240mm for cars with rear discs.
Please bear this in mind if you order JDM parts (or even European, as we have rear discs too) for your conversion.
Al.
Old May 22, 2006 | 12:37 PM
Jonniedee's Avatar
Exclamation
...or a third option - Dust shields front and back to match!
Old May 23, 2006 | 07:20 PM
dacalac's Avatar
Booooo!!
