USB Port to Charge cell phone, etc
Old Oct 14, 2008 | 03:53 PM
fitscott's Avatar
Has anybody tried connecting their cell phone, palm pilot, bluetooth device, etc to the USB port to see if it charges it? Clearly, there won't be any data/music connection . . . but I have several devices that can be charged when connected to the USB port of a PC.
I've heard that this is a powered port (it charges an iPod), but didn't know if it would charge anything else.
Old Oct 14, 2008 | 04:43 PM
TWGE08's Avatar
I can test it on a blackberry but I know sometimes there might not be enough current available on the USB and the blackberry gives a warning message and won't charge. I'll try it tonite when I get home.
Old Oct 14, 2008 | 05:55 PM
jdmgpw04's Avatar
its weird cause sometimes it will charge my non 3g iphone but it wont on my 3g iphone.
it does charge my jawbone 2 though with no problem.
Old Oct 14, 2008 | 06:57 PM
KCHoosier's Avatar
I have a Sansa Sandisk MP3 player that will charge through the port. It won't play music, since it isn't Apple iPod, but it charges the battery.
Old Oct 14, 2008 | 07:31 PM
can you hardwire a 12v to USB cable and just hide it away when not in use?
Old Oct 14, 2008 | 08:15 PM
TWGE08's Avatar
I think USB only uses 5v not 12v so unless you want to get a voltage regulator then you just can't hardwire it.
Old Oct 14, 2008 | 09:06 PM
BlackUp's Avatar
I wonder if you could use a usb hub with this? If so, could it provide enough current to do all kinds of things?
a hub like this:
maybe add a usb notebook light to the glove compartment? like this:
Hong Kong SAR USB LED Light. Manufacturer
nah, you might as well spring for the flexible usb powered "neon" light. like this:
On Sale, buy Magic neon wire - blue Flexible USB Neon Wire - USB or Battery powered
or maybe keep a beverage cold in there? like this:
Google Image Result for http://www.slashgear.com/gallery/data_files/1/4/6/usb_fridge_front.jpg
Old Oct 14, 2008 | 09:14 PM
GRIFF's Avatar
How about a USB toaster?
Old Oct 14, 2008 | 09:20 PM
BlackUp's Avatar
anyone?
Old Oct 14, 2008 | 09:25 PM
ye fit's Avatar
my Sprint HTC Touch works for Charging but I can't play the mp3s from it.
Old Oct 15, 2008 | 02:24 AM
LimpBagel's Avatar
The manual says don't use a USB hub.
Old Oct 15, 2008 | 08:27 AM
Tastycakes's Avatar
I remember reading something like the iPhone (maybe 3g) will only charge if it's in airplane mode.
Old Oct 15, 2008 | 10:08 AM
FitStir's Avatar
Originally Posted by BlackUp
In the UK brochure the 1.4 i-VTEC ES gets a refrigerated top glove box.
http://www.honda.co.uk/cars/_assets/.../jazz/Jazz.pdf
pg 35 in the brochure (pg19 of 27 in the pdf file)
I want that!!!!!!
Old Oct 15, 2008 | 02:35 PM
TimeTTackFIT's Avatar
dam u '09ers and ur fancy usb port! Rock the AUX for life!
Old Oct 15, 2008 | 06:00 PM
mole177's Avatar
^ we have that too... but it's too old school. lol
Old Oct 15, 2008 | 10:08 PM
SheepNutz's Avatar
Nah, people have confirmed that the iPhone, 3G or otherwise works fine. The charging issue people though might occur is because Apple stopped allowing charging from the firewire pin on the 3G iPhone. It only charges on the USB pin now, but that's no problem since the Fit uses USB anyway. The reason that the phone will ask you to put it in airplane mode is to cut down on GSM buzz that can sometimes come through unshielded speakers. This only happens if the phone is on the EDGE network, not 3G, and as far as I know, people haven't had any problems with GSM buzz at all. It can vary from car to car. I get no buzz in my wife's Prius, but I get it in my work vehicle (Dodge Caravan) if I don't keep the phone far from the speakers or head unit.
Old Feb 18, 2010 | 01:27 PM
dmctom's Avatar
Jawbone 2 USB Charging
I got a reply from Jawbone Corp regarding the Honda's USB connector charging a Jawbone unit:
Dear Tom,
Thank you for your inquiry!
The USB charger cord that is supplied for the Jawbone 2 would work great in your Honda's built in USB port.
As long as you use the actual USB cord that was supplied for you it should work fine!
If you have any future emails don't hesitate to email again!
Sincerely,
Moriah
The Jawbone Support Team
Old Feb 18, 2010 | 06:07 PM
BillMc1's Avatar
When in doubt, read.
My 7th and 8th grade homeroom teacher said this to us every day.
Old Feb 18, 2010 | 06:14 PM
dmctom's Avatar
Are you referring to the Jawbone manual? I don't have it anymore that's why I wrote to the Jawbone company directly. Is a "hub" different than the USB port in our cars? Your teachers are very wise indeed...if you don't toss out the manual! LOL!! Hopefully the Jawbone company is wise as well and wouldn't give out misleading information.
AnderuJohnsuton's Avatar
Theres a thread on here about someone mounting and playing music from their Motorola Droid. I also have a Droid, but have not tried it.
